Like Tree22Likes
Old 11-04-2010, 08:04 PM
  #3061
Konich's Avatar
Got my goodies from A-main today. Time to build my spare diff it looks like. Also replace the servo horn after last night
Plastic side plates are in, alloy is out! I think I might even get rid of the carbon brace in back and go to plastic.
Now if GrapeJuice would design a new track layout I might be happy
Konich is offline
Old 11-04-2010, 09:30 PM
  #3062
R-E-A-P-E-R-'s Avatar
It's my job to give Danger a hard time. Him and I are the minority here in CO against a bunch of nitro huffing morons.
R-E-A-P-E-R- is offline
Old 11-04-2010, 10:10 PM
  #3063
dangerwr's Avatar
Ha-haa! Do you thin MHOR will be rebuilding the track soon? I like it but was just curious on the frequency which they change the track.
I need to have a spare diff on tap I believe but so far so good with the P5 o-rings.
dangerwr is offline
Old 11-04-2010, 11:33 PM
  #3064
makaluch's Avatar
Trader Rating: 36 (100%+)
Can someone explain the rear diff twisting and popping out the center rear cvd?
I've seen a few with zip-ties and heard about flex a few times. I'm just wondering what's up, design-wise, and what I can do to avoid or prevent it from happening when I get mine.
makaluch is offline
Old 11-05-2010, 03:27 AM
  #3065
MaTt 93's Avatar
hey,
What diff o rings are you guys running? I heard that you can run the kyosho o rings but im not sure?
Thanks,
Matt
MaTt 93 is offline
Old 11-05-2010, 04:23 AM
  #3066
Dlewis4's Avatar
Trader Rating: 148 (100%+)
For the 5th time in 5 pages... Lol
Kyosho P5. I posted the part number a page or two ago at the top of the page
Dlewis4 is offline
Old 11-05-2010, 04:47 AM
  #3067
MaTt 93's Avatar
lol... must of ad a brain fart and missed it
MaTt 93 is offline
Old 11-05-2010, 05:01 AM
  #3068
Dlewis4's Avatar
No worries
Dlewis4 is offline
Old 11-05-2010, 05:30 AM
  #3069
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
The the big weight makes a huge difference in the rear. No need for these 1* hubs now. I just need to get my diffs to stop leaking.
t0p_sh0tta is offline
Old 11-05-2010, 08:38 AM
  #3070
pmes's Avatar
All you need to do is make sure the drive line is nice and loose. Grab the front and rear drive shafts before you clamp in the spur gear and give them a few turns back and forth to make sure they feel nice and loose. If not they will get hot enough to melt through the diff case and collar.
pmes is offline
Old 11-05-2010, 09:40 AM
  #3071
grapejuice's Avatar
Trader Rating: 152 (100%+)
If you build the car correctly=no problems. I have not had a single issue with my car.
grapejuice is offline
Old 11-05-2010, 10:05 AM
  #3072
i dont get the diff case prob. can someone explain. the only heat ive got in mine was the rear output shaft on my rear diff. was warm to the touch (on the back of my fingers where the skin is thin) but only when i was low on diff fluid. stupid x-rings! my kit is a 2009 spec and so far no problems what so ever w/ the 1.5mm driveline, but it was built right, and im not running a 5t motor. 8.5t seem plenty for any indoor track, and im not even running any timing.
cbrociuos is offline
Old 11-05-2010, 10:53 AM
  #3073
makaluch's Avatar
Gotcha...that explains the twisting diff thing.
  • Kyosho P5 o-rings in the diff for no leaks.
  • Roll the driveshafts and check for binding...often.
makaluch is offline
Old 11-05-2010, 03:31 PM
  #3074
Briguy's Avatar
Trader Rating: 125 (100%+)
+1 , only issue I had is once I went to lower diff oils I noticed the diffs starting to leak . But I have the P5 o-rings , just need to put them in .
Briguy is offline
Old 11-05-2010, 03:37 PM
  #3075
Dlewis4's Avatar
I just put my P5's in... big difference in the stiffness of the diffs now... had to drop oil weights
Dlewis4 is offline
