Like Tree22Likes
Old 06-15-2012, 04:54 PM
  #10561
wfdfiremedic's Avatar
Originally Posted by hotdognobun
yes
Awesome...Thanks so much! Just asking because I have some shorties and am possibly going to pick one of these up. How do you feel the car runs with the shorty?
wfdfiremedic is offline
Old 06-15-2012, 07:09 PM
  #10562
AP3XMONK3Y's Avatar
Has anyone tried running a 25p/87s setup with an heat sink/ cooling fan on the motor and if yes what where ur temps
AP3XMONK3Y is offline
Old 06-15-2012, 11:40 PM
  #10563
I'm using a 20p and 87s with a 6.5 and temps are 140-150ish on motor after a 7min heats/main and 110 on esc with fan.
derbrylac is offline
Old 06-16-2012, 09:15 AM
  #10564
hotdognobun's Avatar
Trader Rating: 32 (100%+)
Originally Posted by 1slash
My Dex410 seems to be making a very odd sound that I thought was normal until I heard a couple other Rangos running.
It is kind of a rattling clunking sound, hard to explain but what are some specific areas I should check when my vehicle is making unnormal sounds?
the diffs are fine and I have just replaced all the bearings in the vehicle to avid. when I just run the spur and pinion without the center driveshafts connected it sounds fine.
Any help would be great.
just watched the vid and heard it. remove motor then rotate both rear wheel same direction by handand feel for any friction? have you tried electrics on another shaft car? maybe motor or even esc is having issues? best of luck trying to solve it and nice ride
hotdognobun is offline
Old 06-16-2012, 01:18 PM
  #10565
Jammin57's Avatar
Trader Rating: 120 (100%+)
I bought a new v1 with motor,esc, battery and servo pretty cheap is there any thing that really needs to be upgraded or is there any parts that usually break and also is the battery tray dimensions the same on the v1, v2 and the v3, thanks
Jammin57 is offline
Old 06-17-2012, 09:57 AM
  #10566
Ill try to answer this only because I have been reading through this thread. I am going to be getting a 410v3, so I have no personal experience yet. The battery tray dimensions are not the same on all three. I believe the v1's have slightly less height and cannot accept some of the taller lipo packs. You can however upgrade it to accept packs up to 25.1 mm. Also, i think a lot of people have upgraded the v1 diff hoops to aluminum. This is especially true for the rear. I guess the rear diff can twist etc and become faulty. That's sort of what I have picked up so far reading the thread. Also, you may want to upgrade to the 14mm hexes that TD uses now on the V3.
Check out tresrey USA too. They make a lot of nice upgrades for the 410.
Old 06-17-2012, 04:28 PM
  #10567
Trader Rating: 44 (100%+)
the Durango alu rear diff hoop allows the battery saddle height to be adjusted - it has 2x slots that allows 2 different heights. you might be able to solve any battery height issue by just getting this alu diff hoop. i'm not sure if the Tresrey diff hoop has this adjustment (i don't have it with me to compare)?
i've got a v1 car and this + servo horn are the only things i've changed.
wyl03 is offline
Old 06-17-2012, 06:33 PM
  #10568
Jammin57's Avatar
Thanks for the answers, I'm not much into electric but some of us nitro guys are getting some 1/10 scales to run at a indoor track
Jammin57 is offline
Old 06-17-2012, 10:20 PM
  #10569
just checked mine and the tresrey hoops has two holes for height adjustments
Old 06-17-2012, 11:51 PM
  #10570
I found that on the V3 the Tresrey hoop is still too low and had to be raised by 1mm to get the same height as the original plastic hoop.
AmiSMB is offline
Old 06-18-2012, 06:51 AM
  #10571
Default Indoor Carpet Track
Hi Guys,
Soon our local hobby shop is going to built indoor carpet track, any idea which compound and tire tread are suitable for it?
GodOfWar is offline
Old 06-18-2012, 02:03 PM
  #10572
Originally Posted by GodOfWar
Hi Guys,
In the UK we usually use Schumacher mini pin in yellow compound on the front and rear when running on carpet usually Prima Felt. To calm things down you have to cut the outer row off on the rear and inner and outer on the front. With mini pin tyres it can take a run to scrub the tyres in before they provide their full grip.
AmiSMB is offline
Old 06-18-2012, 02:27 PM
  #10573
wallot's Avatar
yellow Mini Pins with pins cut is the most used tire on carpet
mini spikes for astroturf
wallot is offline
Old 06-18-2012, 03:39 PM
  #10574
Hi Guys,
As the others have said, yellow mini pins.
If you find your are cutting a lot of rows of the front to lose steering, you can use 2wd front tyres and cut less rows off. I find the sidewall is stiffer as its been stretched, so you lose more steering (410 has never lacked steering !)
Chris-s is offline
Old 06-18-2012, 04:13 PM
  #10575
MikeFriery's Avatar
Trader Rating: 19 (100%+)
Anyone interested in a 410 built and raced only at Cactus.. with almost full tresrey gear?
MikeFriery is offline
