Tekin RX8 1/8 Scale Brushless ESC Thread
Does anyone know how many Amps does a t8 1900 with an RX8 pull?
At my local track a lot of people are using 4s 20c 5000 Mah batteries and I want to make sure there is enough amps there for the motor and battery before I try that set up.
I used to use 40c batteries but if 200c will work I would like to try.
40c is 200amp. (5000 x .04)
Usually want no less than 125a, but some say 150a.
Same exact set-up in the same car for about 3 years. Seemed to start after I updated the software in December. That could be purely coincidence.
Airtronics m4- fhss2 receiver
Hitec 7955
No bec but could probably use one. Pt dims but has never missed a lap.
Hi all. What runs better, 1700kv on 5s, or 1900kv on 4s? I currently have 1700kv on 4s in a buggy, it was bought from someone else. Looking to change, but not sure if batteries or motor? Keep hearing this "voltage is your friend" and want to go 5s, but not sure??
I don't race, may hit up the track but dont have to follow any 4s rules or anything
Just looking for what runs better in my ve8
Whats the update on the Gen2 RX8 ? anybody knows when will they be shipped i`m getting my Associated truggy on thursday , allready have my T8 1550 sitting pretty in the box that it came in , starting to get anxious
Another idea is to plug the esc into ch1 and leave the servo unplugged. What is that result?
I have an rx8 and a scx 7.5 motor that I got from a team driver used... for sale $50 the esc needs a case I never ran it.
Also not sure why I said m4. It's an m11 transmitter.
6s is too much for the 1700kv motor. Just make sure you drop a couple teeth on the pinion when you jump from 4s to 5s as you will literally have 25% more rpm.
I'm trying to get a better understanding of push control since I've never played with it before.
1) How long is the duration between throttle to neutral?
2) How much throttle is applied during the time frame?
3) If I increase or decrease push control am I lengthening/shorting the "ramping down" duration or the amount of throttle being applied over a fixed time?
Thanks guys.
Thanks guys.
Tried again. Different savox servo, diffrent receiver, tried different channels, tried without a servo, tried without pt. Result is still the same. Esc will not arm unless I quickly actuate a servo. Once I do that all is well.
1) How long is the duration between throttle to neutral? There is essentially an "up" timer that counts how much time spent at 100% throttle. The more time spent, the longer the PC pulse is.
2) How much throttle is applied during the time frame?This depends on the amount of push set.
3) If I increase or decrease push control am I lengthening/shorting the "ramping down" duration or the amount of throttle being applied over a fixed time?You're increasing the "power" of the push. The "time" is calculated every time WOT is seen.
Thanks guys.
Thanks guys.
