Tekin RX8 1/8 Scale Brushless ESC Thread >
Like Tree3Likes
Old 06-12-2012, 09:30 AM
  #15601
Team Tekin
Randy_Pike's Avatar
Originally Posted by ta_man
Randy, et al:
You guys generally recommend 40C+ packs for the RX-8 and 1/8th scales.
What do you have to say about SMCs new "Premium Certified" packs that are rated 25C based on measured discharge characteristics, rather than marketing propaganda: http://www.hobbytalk.com/bbs1/showthread.php?t=357870
I'd have to test it. I've said before that I've tested batteries at 30c and 35c that were "true" 30-35c packs without puffing. Protek for example has some 35c packs that I'm using now to save weight and they don't puff.
A pack that puffs is either being ran below a safe voltage cut off range or isn't rated with enough C to provide the power the system is asking of it. If you're "1,000,000 C" rated pack is puffing, you're being lied to
Randy_Pike is offline
Old 06-12-2012, 12:28 PM
  #15602
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Randy, tried to pm you this but it bounced, hope you can help.
I am thinking of picking up or doing a conversion of an HPI Savage to a 5SC Flux (conversions will be with either a TCS or Alza Racing conversion).
The stock electronics appear to be a castle MMM and the HPI version of the castle 2200Kv motor.
as I have been a bit spoiled by sensored operation, I wanted to see if the Tekin RX8 can handle 6S use with a truggy sized Tekin motor in similar specs to the castle stuff in this vehicle without voiding the warranty. If not, no worries.
Cain is offline
Old 06-13-2012, 10:44 AM
  #15603
chucko's Avatar
On the RX8 with a 4600 pro 4 motor, or any motor ....turning down the current limit to 50, 60 %... does it affect the top end speed or just control the burst at take off ? and to what rpm does it cut off IF it does ? and run regular or does the current also limit heat from not used power transfer to the esc ? Thanks
chucko is offline
Old 06-13-2012, 10:49 AM
  #15604
Krio's Avatar
Trader Rating: 159 (99%+)
http://kriostasis.com/news/?p=23
Krio is offline
Old 06-13-2012, 10:53 AM
  #15605
weavty1's Avatar
Questions??
Originally Posted by Krio
Is that legit?? Like your explanation? Just curious! thx!
weavty1 is offline
Old 06-13-2012, 11:00 AM
  #15606
Team Tekin
Randy_Pike's Avatar
Yes it works fine. 6s in that setup I'd go with a 1550 or 1350.
Old 06-13-2012, 11:02 AM
  #15607
Team Tekin
Randy_Pike's Avatar
http://www.teamtekin.com/hotwire_RX8.html
It doesn't affect top speed directly as it's doesn't limit the speed of the motor. It only limits the amount of power the motor can have on initial take offs.
Old 06-13-2012, 11:09 AM
  #15608
Tech Legend
Cain's Avatar
Great. Going to do a bit more research then. Have you guys tested the RX8 at all in the new HPI 5SC Flux? Curious if you have any suggestions on ESC settings.
Cain is offline
Old 06-13-2012, 11:10 AM
  #15609
Krio's Avatar
Yes, it's legit. lol
I posted that exact info a month or two ago in this thread (not that I would expect anyone to read the whole thread for a single bit of info) and since I finally got my personal website up and running it seemed wise to start copy/pasting any quality posts I do to my easily searchable site. That way when the info gets buried in a couple weeks and someone else asks I can just post a link.
Krio is offline
Old 06-13-2012, 11:36 AM
  #15610
Trader Rating: 35 (100%+)
Great info, very nicely written.
kazuaki is offline
Old 06-13-2012, 11:54 AM
  #15611
Team Tekin
Randy_Pike's Avatar
Never ran the Baja 5 setups. I will tell you that the Rx8 isn't meant for that application though.
Old 06-13-2012, 12:16 PM
  #15612
DaveW's Avatar
Good info Krio...
DaveW is offline
Old 06-13-2012, 01:40 PM
  #15613
chucko's Avatar
Thanks Kiro.. nice read
chucko is offline
Old 06-13-2012, 01:43 PM
  #15614
chucko's Avatar
so when you come up to that jump that you need all it has, does this limit the launching capability or just at dead stop start >?? Sorry to beet a dead horse.
chucko is offline
Old 06-13-2012, 01:46 PM
  #15615
Krio's Avatar
Yes, it would limit that. Short run up jumps are a good place to find the 'minimum' setting you should use at a given track.
Krio is offline
