Tekin RX8 1/8 Scale Brushless ESC Thread
Randy,Help Needed...I have a new Losi SCTE,1 race old rx8,new pro 4600 motor,1 race old KO ex-10 eurus radio system with ko DSM,New maxamps 6500 150c 2 cell lipos and I have a slight cogg from a dead stop sometimes.I have tried 3 NEW sensor wires,re- load 223 software/firmware several times and this small cog will not go away..What needs to be done to get this GONE....sensor checks to be good.I am running 0 timing and 80% current limiter.
I have tried caps in the reciever.I running a futaba 9351 servo..
Remove the pinion and try to power the motor VERY slowly while watching the sensors. Make sure all the are cycling on/off while under power. If they go out the Rx8 already moved to dual mode, try again. It may take a few times to get it. You can cheat and use your throttle trim to get the required input.
Where are you geared? How much timing is set in the esc?
hard case
do turnigy nanotech come in a hard case ? I thought they were soft packs
you get what you pay for
click here for test and diagram
two batteries testet (green/blue)
3x50sec 10C, 3x5sec 25C, 1x60sec 15C, 1x5sec 20C,
on left side is the voltage, in the middle is the time an right the C rate.
useable cap. is 5100mha, internal resistance is 6,6milliohm...waaaaay to much.
65-130C??? never ever....looking at the diagram the accu is a poorly a 25c.
only good thing is the drift..bette sayed: nearly no drift
This is not "battery chat" guys....Let's keep on topic.
Hey Randy,
What would be good gearing to start with for a medium to large outdoor track on a Losi 8 with the RX8/1400kv combo on 6s?
Pardon me for asking a stupid question,,,,, BUT... which way are y'all mounting the fan on the RX8? Label up towards the cage? or down toward the heatsink?
Thanks in advance!
Thanks in advance!
batt
sorry Randy.
back to RX8
still cant understand why car takes off in reverse when signal is lost ?
Me mates car does the opposite . Takes off forward .
Any ideas on what we should do ?
Sorry to say this Randy, the fans do not last long in off road situations. Try running without, they usually tend to be fine heat wise. Run a pack through it and check the temp every few laps. If you are geared right and have some vent holes in the body, you should have no problems. I gave up on the fan after ending up with one blade left. I noticed only a few degrees in temp rise but never gets over 3 light on the onboard temp. I run a rx8/1900 with 15/46 gears on a Mugen eco. Hope this helps.
mydex408 doesnt have any issues with the fan breaking but i think its because the body sits so low that the shock towers protect it when it flips over.
I race outside in 95-100 degree heat. Heat index of about 112.. And thats at 8 o'clock at nite. Then there's the 100% humidity as well...
Still think I don't need a fan?
full reverse when signal lost
back to RX8
Any ideas on what we should do ?[/QUOTE]
Have binded transmitter to rx8 after using hot-wire.but still full reverse failsafe .
new question ------ is this because ive sellected reverse delay setting ?
ie no fail safe if reverse is used .
Anyone ?
Anyone ?
