Tekno RC ET410 Thread >
Like Tree464Likes
    Hide Wikipost
Old 03-02-2020, 09:56 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC ET410 Thread
Last edit by: rustyus
Welcome to the ET410 Wiki page.
  • 95% parts compatibility with the EB410 4WD 1/10th scale buggy.
  • Updated 3mm 7075 CNC chassis and revised A and B hinge pin braces.
  • 13mm hard anodized threaded shocks with locking spring perches.
  • New 32 pitch spur gear for ultimate durability
  • 3.5mm shock shafts with revised dual guide x-ring cartridge.
  • 7075 CNC machined adjustable hinge pin brace system.
  • Three high volume fluid-filled adjustable differentials.
  • Lightweight 7075 tapered center driveshafts.
  • Quick access to differentials and maintenance friendly layout.
  • Captured CVA front and rear driveshafts with heavy duty 6mm stub axles.
  • Fully ball raced reverse bellcrank steering system.
  • Uses 1/10th AE Offset Stadium Truck or Traxxas Slash Short Course offset wheels.
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and it’s pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
Parts Needed to convert from EB410 to ET410
Pin Replacement Tool options
Inner Hinge Pin Inserts- Degrees of Adjustment
Upgrades:
Print Wikipost
Old 05-21-2019, 10:25 AM
  #886
Originally Posted by Tbuggy
The EB does it too. You can solve this with a 1-2mm spacer.
thanks, that's exactly what I did!
scott_0 is offline
Old 05-21-2019, 01:35 PM
  #887
suzukipro's Avatar
Trader Rating: 33 (100%+)
Originally Posted by sea1swk
ooo, Carisma front bumper? what would that be? I'm using tbone Racing front and rear eb410 bumpers. But the front is about 1/2 inch under Roar rules for with. Rear is great. sc6.1 bumpers are not a great fit.
https://www.carisma-shop.com/en/product_detail.php?id=91&fbclid=IwAR3fpb1yZLvkTQ-N6F2HeW2w__DLJXjaXuLud7tQ3_x2UgKYqP4SQmvnyBI
I only used the front bumper as they come as a set.
suzukipro is offline
Old 05-22-2019, 02:32 PM
  #888
platgof's Avatar
I put a Tekin Pro4 4600 in this with an RSX esc. I haven't run it yet, but should race it sat. I talked to Tekin and will send the unopened 5100 back to them when it arrives. I am sure the Pro4 4600 will be all the motor I will ever need. Setting these up is very similar to setting up a 4wd sct, same servos and same motors.
platgof is offline
Old 05-23-2019, 06:52 AM
  #889
anyone running the Lunsford titanium turnbuckles? not real big on having to re-size the rod ends
scott_0 is offline
Old 05-25-2019, 04:23 AM
  #890
rustyus's Avatar
Default Spring Clearance
Originally Posted by scott_0
so I got my et410 yesterday, bought it from a guy on facebook on the tekno buy/sell group, great truck that was never ran. he had it converted to front mount rear shocks, I want to run a Finnisher body so I converted it back to rear mounted shocks, after getting it all back together, my spring and spring cups are barely kissing the driveshaft/dog bone on both sides of the truck, I ending up making a pair of plastic spacers to get the needed space, anyone else have this issue? I went by the manual and verified everything is put together properly
I also spaced the bottoms of the shocks back 2mm to make sure the springs cleared everything. While I was at it, I replaced the TKR1240 M3x18mm Shock Mnt Screws with normal M3 20mm button head screws. I never had a screw come undone on an arm before. The reverse threads on the TKR1240 screws would just mess me up on my screwing/unscrewing practices .
rustyus is offline
Old 05-25-2019, 05:47 AM
  #891
rustyus's Avatar
While on the spring subject, my stock Yellow rear springs are too short to allow me to get the ride height I am after. At full droop, I have the shock adjustment collars just touching the top of the springs. When I push the truggy down; let the shocks do their thing; the ride height is too great, and I can not get the rear to "bones level". If I loosen the collars to get bones level ride height, the rear springs will come off the spring perch at full 108mm droop...not good.
I had to go to the softer rear Green springs in order to (barely) get my ride height that I was after.
rustyus is offline
Old 05-25-2019, 06:41 AM
  #892
Trader Rating: 35 (97%+)
Sorry I didn't clarify, but that is what I was talking about. There is no need for spacers on the top of the shocks.
Tbuggy is offline
Old 05-25-2019, 02:36 PM
  #893
raced the ET today, which also was the first time I've driven it, and while I didn't set any lap records, I had a great experience racing this thing, it is an absolute blast to drive!
wrightcs77 likes this.
scott_0 is offline
Old 05-25-2019, 03:11 PM
  #894
platgof's Avatar
What an awesome track!! I would love to race there. Today I had to leave a race because too much dust. Not a bad layout, but my sinuses kill me already. Where is that?
scott_0 likes this.
platgof is offline
Old 05-25-2019, 04:14 PM
  #895
Pit Stop Hobbies in Mount Joy Pennsylvania, great track and they run a great race program, it's a 40mi drive one way for me, but 100% worth it, they have a well stocked shop on site as well
scott_0 is offline
Old 05-25-2019, 05:34 PM
  #896
platgof's Avatar
I would do 120 each way for a track like that! I thought it was North East, but not sure where. Looks like the perfect ET410 track to me.
scott_0 likes this.
platgof is offline
Old 05-25-2019, 06:15 PM
  #897
what's the AE shock oil equivalent to the Tekno 550cst and 350cst oils?
scott_0 is offline
Old 05-25-2019, 06:27 PM
  #898
platgof's Avatar
Originally Posted by m59y
I was using the Pro2 5100. It had great top end but didn't have the bottom end I wanted. This gave it more of an on/off feel. I switched to s Hobbywing 3800 at half the price and couldn't be happier. Running 19 or 20 pinion and equals the speed of the Pro2 with a lot more bottom and mid range
I looked at Tekin's site on the Pro2 and Pro 4 and they do not advise using the Pro2 for the ET410 but for 4wd buggy class, the Pro4 4600 is for the ET410 class. I put the Pro2 5100 in my B64D and it does great in there. The ET410 is too much for the Pro2. The Pro4 4600 has no problem with the ET410 as suggested by Tekin. At first I was going to return the Pro2 5100, but decided to try it in the buggy, and glad I did. With the RSX you can run dual mode by disabling the sensor in mode one. These 4 pole motors run so cool, and are plenty quick. I am experimenting with gearing and temps to get as much speed as needed. The ET410 takes a lot of power to move it as it is heavier than a buggy, and we already know about the servo issues as those big tires can really beat it up. I wanted to add that the Pro2 5100 takes the smaller 3mm shaft pinion, and the Pro4 takes a 5 mm shaft. I also had to modify the motor mount bracket to allow access to the pinion set screw.
platgof is offline
Old 05-26-2019, 05:20 AM
  #899
platgof's Avatar
I was okay with your picture untill I seen the pretzels! What low move was that, they look great.
platgof is offline
Old 05-26-2019, 07:46 AM
  #900
gotta have that between race snack!
scott_0 is offline
