Tekno RC ET410 Thread >
Like Tree463Likes
    Hide Wikipost
Old 03-02-2020, 09:56 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC ET410 Thread
Last edit by: rustyus
Welcome to the ET410 Wiki page.
  • 95% parts compatibility with the EB410 4WD 1/10th scale buggy.
  • Updated 3mm 7075 CNC chassis and revised A and B hinge pin braces.
  • 13mm hard anodized threaded shocks with locking spring perches.
  • New 32 pitch spur gear for ultimate durability
  • 3.5mm shock shafts with revised dual guide x-ring cartridge.
  • 7075 CNC machined adjustable hinge pin brace system.
  • Three high volume fluid-filled adjustable differentials.
  • Lightweight 7075 tapered center driveshafts.
  • Quick access to differentials and maintenance friendly layout.
  • Captured CVA front and rear driveshafts with heavy duty 6mm stub axles.
  • Fully ball raced reverse bellcrank steering system.
  • Uses 1/10th AE Offset Stadium Truck or Traxxas Slash Short Course offset wheels.
For you guys all discussing what power plant to run, I would take note of the following statement from Matt W.
Matt - Probably would recommend a 10.5 for something similar to 13.5 in a buggy. I personally run a 6.5 in it and it’s pretty fast. Pro4 4600 will run in it but it has a lot of power and will need to be turned down in the esc.
Parts Needed to convert from EB410 to ET410
Pin Replacement Tool options
Inner Hinge Pin Inserts- Degrees of Adjustment
Upgrades:
Print Wikipost
Old 04-30-2019, 09:26 AM
  #856
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Originally Posted by Tbuggy
I just finished up a little project I had been working on from scratch. Finally got everything all together, just need to do some soldering now and some testing. The idea was to make a LCG version of the ET and compare performance. I also have the PR truggy ordered and the LCG was a big part of the hype for this truck and was also inspiration for the modification. I think I accomplished what I was trying to. At least the shocks, towers and body noticeably lower than the original.
My LCG ET
Original ET
Side by side. You can see the noticeable difference in roof and shocks height. The original ET does have its ride height at 27mm currently and the LCG ET is at 25mm but you can see the difference is a lot more than 2mm.
LCG ET
Original ET
Tell me what you guys think so far!? I am hoping to get a chance to get to the track later this week and do some side by side test runs between the two. And then in a couple of weeks after I get my PR truggy I will test that against this as well.
So you put on buggy towers. Did you put on buggy shocks, too? Didn't look like a whole lot of shock up travel available in the pics. Does the chassis bottom out before the shocks fully compress?
Like the idea and thinking, just some questions I had.
wrightcs77 is offline
Old 04-30-2019, 10:08 AM
  #857
Trader Rating: 35 (97%+)
The chassis will hit the ground before the shocks bottom out. I did use buggy towers and went with the ET shocks first. I do have a spare set of buggy shocks and will probably try them out if I feel the need to. I haven't ran this yet and who knows it could flat out suck in comparison (although I highly doubt it ;-) ). Definitely excited to see how it handles differently.
Tbuggy is offline
Old 04-30-2019, 11:06 AM
  #858
damn it I'm going to end up with one of these if I keep visiting this thread lol, my shop said they'll have a new shipment in tomorrow, looks like I'm going to grab one
aspiringracer and Tbuggy like this.
scott_0 is offline
Old 05-01-2019, 04:39 AM
  #859
Trader Rating: 36 (100%+)
You may find that the shocks will bottom out in corners when the chassis rolls. I did something similar to my XT2 this winter, used buggy shocks and made shock towers with the correct geometry. It was fine on straights, flat landings and low speed corners but when the chassis rolled too far the shocks would stack up and the truck would pivot on that corner and the back end would come around. Hopefully yours doesn't have that problem.
Tbuggy likes this.
nitrousdave is offline
Old 05-01-2019, 07:24 AM
  #860
You may be right and that is why I have some buggy shocks on standby to try if that is something that ends up causing an issue.
Tbuggy is offline
Old 05-03-2019, 08:48 PM
  #861
R/C Tech Elite Member
lowspark's Avatar
Will a 23t pinion fit on the ET ?? I just put a 22 on mine and it seems like the motor mount is at it's maximum width.
thanks
lowspark is offline
Old 05-04-2019, 11:16 AM
  #862
I tried a 24 tooth pinion and it fit but seemed like it was the biggest that would fit.
Redtail2426 is offline
Old 05-04-2019, 03:58 PM
  #863
RCSteveH's Avatar
My LCG ET
Original ET
LCG ET
Original ET
I installed the VRP +4mm towers on mine. The car bottoms out on the smallest jumps with ST Tires. There’s 4mm less suspension travel before the chassis bottoms out. Go with the SCT tires and you’ll be much better.
But it honestly, stock towers with ST tires is the best combo for me.
RCSteveH is offline
Old 05-04-2019, 06:34 PM
  #864
platgof's Avatar
Yanked the 5.0 motor and installed a 6.5 to see what happens. The 5.0 seems to slow for me.
platgof is offline
Old 05-05-2019, 10:10 AM
  #865
Trader Rating: 15 (100%+)
Does anyone know the length of the rear shock shafts? A lot of EB410's run 30mm of droop now and this requires unscrewing the lower shock eyelet quite a bit (3mm+). It's a bit unnerving. If the ETrear Shock shafts come close they may be worth a shot to try, even if some threads need to be cut. Thanks in advance.
aspiringracer likes this.
HeavyD99 is offline
Old 05-19-2019, 09:27 AM
  #866
What are you guys using for a servo on these units. I was going to go savox but had issues in the past where I had someone add a bec to make it work properly.
jpedersm is offline
Old 05-19-2019, 11:24 AM
  #867
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
i'm using a protek 155T. no issues.
RC*PHREAK is offline
Old 05-19-2019, 11:36 AM
  #868
suzukipro's Avatar
Trader Rating: 33 (100%+)
I converted an ET into an SC410L using a cobra chassis, it is lot more nimble than my SCT410.3. I have since pulled the front diff, driveshafts etc and dropped a 17.5T / B64 slipper in it to try out in stock 2wd Short Course. I need to add weight to the rear to make minimum weight requirements in both configurations.
RC*PHREAK and MaX-D like this.
suzukipro is offline
Old 05-19-2019, 05:17 PM
  #869
platgof's Avatar
Raced this sat and it seemed slow. Trying to decide between a Tekin 6.5 G3 or a Pro2 5100? I am using an RSX and seen someone's setup sheet using this same system with the Pro2 5100. Tekin claims the Pro 2 is a lot stronger motor, so ......
platgof is offline
Old 05-19-2019, 05:26 PM
  #870
RC*PHREAK's Avatar
what are you using now? i'm using a reedy M3 6.5 with their 13.0mm high torque rotor and it's awesome. if you already have the tekin 6.5 and are thinking about ditching it, maybe try their 13mm high torque red rotor.
