Like Tree404Likes
Yokomo YZ-4 SF
    Hide Wikipost
Old 02-06-2018, 06:30 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Yokomo YZ-4 SF
Last edit by: DG Designs
Old 01-28-2019, 10:44 AM
  #751
Trader Rating: 104 (100%+)
Does anyone notice a difference between running the 8 degree front hubs and the 10 degree ones? If you notice a difference, what is it/are they?
Ostach24 is offline
Old 01-30-2019, 11:31 AM
  #752
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Personally I like to keep this guide and the 2wd version in my binder:
http://site.petitrc.com/setup/xray/S...etupHelper.pdf
The description of waht the change does is basically what i experienced with other vehicles, both on and offroad.
Cain is offline
Old 01-30-2019, 12:20 PM
  #753
GiMLit's Avatar
For me I found that moving to the 10deg just calmed it down abit. Allowed an old bugger like to me push the car much harder. Mechanically you can look at the tuning guides to see what you “should” notice but like I said I can simply put it as it is more calm.
btw in case you were not aware you do not need to go with Aluminum the Bmax/yz4 plastics are 10deg
GiMLit is offline
Old 01-30-2019, 12:27 PM
  #754
GiMLit's Avatar
Originally Posted by evolution03
I haven’t been on here in a while so forgive me if this has been discussed a lot. Are any of you guys using the center gear diff on indoor clay ? What diff fluid setups are you guys using ?
I’m not sure that anyone responded to your question. For me on reasonably high bite Clay track I am at 10k - 200k - 7k
GiMLit is offline
Old 02-01-2019, 01:14 PM
  #755
Originally Posted by Cain
Be cool if lunsford offered a conversion for 5.5mm ball studs.
They do offer a 5.5mm ball stud set. I just put one on mine. I also race at Kelly Lunsfords home track so they might not be in stores yet.
NWracer77 is offline
Old 02-01-2019, 02:00 PM
  #756
https://lunsfordracing.com/collectio...-yz-4-sf-14pcs
NWracer77 likes this.
Jeff_S is offline
Old 02-02-2019, 05:04 AM
  #757
thanks flr the post I found it very informational. I’ll keep that with me from now on. Usually I just make small adjustments take it on the track and see if I like it or not. It’s nice to know what I should expect from things, might save me some time in testing.
Cain likes this.
Ostach24 is offline
Old 02-02-2019, 05:14 AM
  #758
Thanks. I may just have to give them a try and see if I like it or not.
Ostach24 is offline
Old 02-03-2019, 07:19 PM
  #759
battery strap options for YZ4 SF, need one with access to balance battery port. Or I guess I could drill out carbon fiber stock one. Maybe one for XB4 or B64 ?
Ramirez24 is offline
Old 02-03-2019, 07:56 PM
  #760
Factory RC - or drill your own.
https://www.amainhobbies.com/factory...ftc070/p739879
Jeff_S is offline
Old 02-04-2019, 07:13 PM
  #761
Anyone using the YZ2-T rear shock body to get more droop? Had a local racer talking about it recently. I've got this thing pretty dialed but I'm always looking for new advantage
Old 02-04-2019, 11:32 PM
  #762
Haven't heard of that. There are some people in the area running YZ2T front shocks in the rear though.
Jeff_S is offline
Old 02-05-2019, 07:11 AM
  #763
Maybe that's what I'm thinking of, to limit droop not give it more
Old 02-05-2019, 07:51 AM
  #764
Trader Rating: 22 (100%+)
we're running max droop on the rear of the car right now. In fact if you look at the Reedy setups, they are using 3mm inboard and outboard with 29mm droop on the alum hubs. That will make it so that your ball cups barely clear the rims at full droop.
Bob Barry is offline
Old 02-05-2019, 11:43 AM
  #765
Default Durability running on carpet
Hi all,
Interested in getting the car but wondering how the durability is of the car?
​​​​​​What other extras/hop ups should I get?
GS76 is offline
