Yokomo YZ-4 SF
#736
A question as to the shim under the rear D (RF) block that is called for in the manual- does this shim count towards the 2 degrees of anti squat when using the center dot/center dot pills? Meaning that if removing the shim and keeping the center dot pills work out to be 1 degree antisquat (since it’s in the rear, that seems to make sense to me).
#737
#738
So basically removing both shims would require running the 1 dot up for the front and rear pills to be at the same point as center dot with shims?
#740
Tech Legend
Had almost another perfect drive time with my yz4sf. Went to a 13.5 setup for our full mod class instead of the 8.5T motor I was using due to the track size and I wanted to get the vehicle more oriented to 13.5 racing for another track I may go to again. did some of the common setup changes to the car like lightweight diff components and some titanium screws. I did also go to the 5.5mm ball stud setup, but just the stock yokomo steel. Be cool if lunsford offered a conversion for 5.5mm ball studs.
I also went with a different team setup to try, biggest difference being the diffs at 10K front and rear I felt than then 7K I was using. Using the same honeycomb tires I used before.
Car was able to set TQ and it I didn't get a super hit in the main that cracked a battery case and knocked out my power wire would have taken the win
I think I am going to go down on the rear diff, back to 7K and try that out again before going to 7K all around as I liked the feel of the car a bit better with 7K all around.
All in all though, car was great. took some hard hits and stayed together from what I can tell other than what I reported.
#741
Yes the spacers are 1mm thick. The number on the pills refers to the offset in degrees, not the distance the pin moves. 1° is 0.6mm, 0.5° is 0.3mm (this info is in the manual)
The spacers move the rear roll center by a large amount, then you can fine tune with the pills or the shims under the camber links. If on carpet, normally run the spacers because of the low ride height.
#742
YZ4 SF with pretty much the kit setup on it. Didn't feel too bad the first time out, oil was maybe a tad light, but good enough for 2nd in its maiden voyage.
#744
Clay track, pretty smooth, guys run proline primes in super soft guys sauce their tires. Track gets watered in between rounds, track temps vary but usually not below 50.
#745
Tech Legend
For the RDRP Steering rack and the shims it includes, I am assuming the black shims go inbetween the bearings and the silver shims go to the steering arm side. So the screws just go direct on the bearings. I noticed however slight binding when you tighten down the screws all the ways. I back off a hair but was wondering if anyone else noticed this.
#746
#747
Does that rack eliminate the slop?
#748
#749
Looking at Mayfields setup, he likes to run v2 ae yellow spring in front, so what is the part# for this. All I find is spring for 1/8 buggy ?
