Xray T1FK05
#2146
need view points on the Tamiya shocks
been thinking of doing this conversion. just need to know what part #'s I need for the mounts and if there are any other issues that I may run into.
also if the xray springs work on the TRF units.
#2147
http://www.arroyoc.com/rcracing/harshshocksa.jpg
http://www.arroyoc.com/rcracing/harshshocksb.jpg
http://www.arroyoc.com/rcracing/harshshocksc.jpg
Here's an email I sent to another guy I race with ...has all the part numbers and stuff that I used:
For Blue:
Shocks:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSA3&P=7
Ball Connectors:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSC8&P=7
For Red:
Shocks:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSA4&P=7
Ball Connectors:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFSC9&P=7
Then you'll need 1 of these xray ball joints:
https://www.ssl-stormerhobbies.com/c...l?pn=XRA303220
And one of these xray ball ends (unless you want to try and take out of your xray shocks):
https://www.ssl-stormerhobbies.com/c...l?pn=XRA303240
...I used the xray aluminum collars as the Tamiya ones where "cheezy"
You will also need 4 - 3 mm lock nuts
On the ball connectors, the shocks come with gold ones, so the colored ones above are just if you want to "color coordinate",
OK, now for the front shocks, you will use 2 of the ball connectors with 3 mm nuts for the top into the shock tower, and 2 of the Xray ball joints with the ball ends put in them on the shock shaft, you'll need to cut the ball end just above the "nut" looking thingee ...where this red line is:
This will go on the bottom with a 3mmx10mm screw into the arm, I made the from shocks 65mm ling
Now the rear shocks, you'll use the short connectors in the tamiya set for the bottom of the shock, you will use 2 of the ball connectors with 3 mm nuts for the top into the shock tower, for the arm you'll screw 2 of the ball connectors into the arms, I made the rear shocks 61.5mm long
xray springs work perfectly
I'm getting a set of these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXETK6&P=7
That I *think* should work instead of the ball connectors were I can put a 3mm screw through them (the ball conectors make me "nervous")
#2148
Originally posted by HarshGuy
I put TRF's on my Xray and I love them, xray springs work on them no problem:
good to hear the xray springs work also. I have every one of um.
hows the up keep on the TRF shocks ? Seems like every 3 runs on the xray units they would go flat and I would have to redo them (I hate bleeding shocks)
#2150
thanks harsh. If I wasnt such a lazy arse I would have searched back a few pages and found that. I remember reading it now.
#2151
I have the front set on the most loose setting possible (the notch that has a big gap before it) and my front belt is still actually a little tight compared to my FK04. Any help will be appreciated.
#2153
Originally posted by dan-o
Hey all I need your help,
I bought a used xray car and need shock plastic parts kit... I checked speedtech and KT hobbies no luck any other online places to look????
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
#2154
I have had very good luck with Robert at Ashford Hobbies.
http://www.ashfordhobby.com/pricing013.htm
I hope this helps, Mike
#2157
I got the ball nuts today from tower and they work KILLER ...the shock wasn't rotating as much as I'd like it to on the ball once I put a screw through it so I put some General Silicon coned washsers with the coned side toward the ball and they work PERFECTLY ...now no worries of anything "poping off":
front shocks:
rear shocks:
front shocks:
rear shocks:
#2158
anybody know the website for prs spur gears
