Tamiya TB-02
Old 03-18-2005, 07:05 PM
  #1276
RCGaryK's Avatar
One of the locals here runs his TB-02 in stock for about 6 weeks before our regional race instead of his 415....and he is darn stout with it. Make sure you invest in things like a front one-way and a set of suspension mounts, along with the spring and swaybar sets too and you'll at least be in the ballpark.
RCGaryK is offline
Old 03-18-2005, 07:27 PM
  #1277
POOKYT's Avatar
Thank you Gary!! Thats what I needed to know
Brant
POOKYT is offline
Old 03-18-2005, 09:48 PM
  #1278
Originally posted by ford_racing
what pitch pinion can I use with my TB02, it has the F201 speed tuned gear set installed??
Thans in advance
Go for the 28 tooth pinion 0.6 module. Kawada model co makes one that suits you can get it from rainbowten.
I currently run it with the tamiya silver can motor in novice class and am getting lap times similar to the guys that run stock class 27t motors.
I also have the 49t spur gear and 31 tooth pinion that I will install shortly !
Phenochilus is offline
Old 03-18-2005, 11:08 PM
  #1279
pyrosian's Avatar
I run my TB-o2 in stock quite happily, last race meet i was 11 milliseconds off the second qualifiers pace. unfortuatly i crashed out before the main
Phenochilus: When are you coming up to stock?? You're damn fast with a 540, you could handle it.
pyrosian is offline
Old 03-18-2005, 11:39 PM
  #1280
KREATOR1's Avatar
your running what motor and ratio for the stock?
KREATOR1 is offline
Old 03-19-2005, 12:15 AM
  #1281
pyrosian's Avatar
I'm using a Matrix V10tt Stock motor with Reedy 767 brushes. I'm running a 7.1 final ratio. I think it's currently a 21 pinion to a 55 or 58 spur.
pyrosian is offline
Old 03-19-2005, 10:19 AM
  #1282
Trader Rating: 28 (100%+)
Originally posted by dsrbltoys
Sorry, still waiting!
So Kevin what gives??? I can't believe you don't have a TNX listed in your sig yet?
madjack is offline
Old 03-21-2005, 04:37 AM
  #1283
badKarma's Avatar
Default Nessesary to Race?
hey guys, thinking of competing in the GT2 class in Laurel MD, what nessecary aluminum parts from the EVO III and EVO IV should i use to make the car more competitive? thanks
badKarma is offline
Old 03-21-2005, 05:56 AM
  #1284
Default Re: Nessesary to Race?
Honestly the only thing that I think really helps is the alloy shocks, and CV swing shafts, the rest is fluff. I qualified 4th in GT2 and should have won, and thats all I have, and the guy that did win doesn't even have swing shafts. Of course the regular TB02 hopups help like the alloy motor mount and such.
GroffBall is offline
Old 03-30-2005, 08:49 PM
  #1285
Default TB-02 Carbon Upper Deck
Has any one tried the following part, if so did it make much difference, or is it pretty much dead weight ?
http://www.tech-racing.co.jp/pic/tb02/ttb050.jpg
Old 03-30-2005, 08:53 PM
  #1286
ford_racing's Avatar
how much is part number 53680, the alloy motor mount likely to cost, I can't find in on the regular shopping places I look at
ford_racing is offline
Old 03-30-2005, 09:03 PM
  #1287
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: TB-02 Carbon Upper Deck
its not TCS legal. so a majority of the US drivers havent tried it. plus the TB-02R is out now.. all though the jury is still out with how much stiffer that car is.
Hebiki is offline
Old 03-30-2005, 09:06 PM
  #1288
f1larry's Avatar
Trader Rating: 22 (100%+)
Speedtechrc sells them for 19.99 but they are out of stock right now. You can also try Rainbowten.com
f1larry is offline
Old 04-01-2005, 03:54 PM
  #1289
westerdude42's Avatar
Default Gears
Can someone please tell me the positives and negatives of running larger pinion or smaller spur to achieve the same gear ratio? I'm trying to gear for a tight technical track and am trying to figure out which combo to use to achieve best results.
westerdude42 is offline
Old 04-01-2005, 04:32 PM
  #1290
POOKYT's Avatar
The larger the spur the more" leverage " your motor will have on the transmission. If you are on a tight track I would use the largest spur possible. LOL I have raced a XXXSG+ for the past 2 years and no matter which track I ran on I always used the largest spur possible. In off-road it will make more difference having the motor pushed back or in closer to the chassis as far as hadling goes. Good Luck
Brant
POOKYT is offline
