Like Tree2Likes
Rc10ntc3
Old 03-22-2003, 12:08 AM
  #2911
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
actually here is the right part for the NTC3.https://www.ssl-stormerhobbies.com/c....pl?pn=MIP3076
and the replacement springhttps://www.ssl-stormerhobbies.com/c....pl?pn=MIP3077
Hope this helps.
Jon
Jon Carlson is offline
Old 03-22-2003, 04:22 PM
  #2912
Originally posted by mr. losi
ok guys, i read a few pages back that the centax clutch is not worth the cash, has anyone tryed the k factory???? or are they all the same???...also, is the mip clutch the same as the gt???? the 4 in 1????thanks.....
For my opinion both the Kawahara and K-Factory made my car more pushfull (what i like) and the wear is less than a 3 shoe standard clutch . I have them both and like them very much. The K-Factory clutch is a little lighter than the Kawahara.
herb is offline
Old 03-22-2003, 09:20 PM
  #2913
Peter Busch's Avatar
what do ou mean by pushfull?
Peter Busch is offline
Old 03-22-2003, 09:40 PM
  #2914
I think he means that the car is snapier(sp?), it launches when you gas it.
Steven Muller
Maximum Performance Parts
nitrodude is offline
Old 03-22-2003, 11:25 PM
  #2915
mugen_kid's Avatar
the centax clutch is only for off the line response wich it doesnt give you any more power on top end. And it is a little bit consistent for perfect bottom end response(tuning), so that the load on the motor isnt instant, therefore the motor revs harder to engauage. This will only work if you got the clutch set right with harder spring and light weight shoes. This can be obtained with the stock ntc3 clutch by altering shoe length or harder spring.
mugen_kid is offline
Old 03-23-2003, 04:14 AM
  #2916
Steven Muller
Yeah, i mean the car is more responsive to throttle when launching my car out of the corners.... (sorry for my bad English)
herb is offline
Old 03-23-2003, 07:37 AM
  #2917
Do they make steel CVDs for the NTC3? I keep breaking my front ones off at the pin, it just shears the aluminum.
Thanks,
Steven Muller
Old 03-23-2003, 11:46 AM
  #2918
FREAKAH's Avatar
The Shiny CVD Bones(bones only) for the ETC3 are the same length and fit perfectly.
Many NTC3 racers here have switched to the Shiny bones because many noticed wear at the pin holes and twisting only after a couple of races after they got their car.
FREAKAH is offline
Old 03-23-2003, 12:16 PM
  #2919
I put those in mine right away along with the IRS pin cusions. TIR makes Titanium bones also.
Old 03-23-2003, 01:29 PM
  #2920
dvargas's Avatar
Hey guys,
I am brand spanking new to r/c and i ordered a NTC 3 RTR and i am wondering what should i get as either extra parts or hop ups, stuff like that???
This is what i have.
(on the way)
NTC 3 RTR
Transmitter case
3 OS #A3 glow plugs
Glow wrench
DuraTrax Standard Screwdriver Set w/Pouch
After run engine oil
Glow starter
(i have already)
500cc fuel bottle
250cc fuel bottle
Nitro fuel
So i should be set when my car and stuff gets here to start bashing.
I just bought a fuel filter today, and i bought a BMW 328 Ci body.
Is there anything that you would recommend getting?? Anything you think of let me know. i would be greatful.
Thanks for your help,
David
[email protected]
dvargas is offline
Old 03-23-2003, 01:36 PM
  #2921
DODGE STRATUS From protoform 2speed Foam tires O yeah Threaded SHock OS 8s works Great . Dont Get Trinity Fuel Sucks Bad rust up your Engine ehh. Get odonnel 20% or My fave Sidewinder 20% pro blend it give me puch but a lil less run time cuz there is only 10% of oil hahah hey if i can beat the cars in my main im happy. If theres any Bushing Replace ASAP. I basically Run a STOCK NTc3 Team Kit No Hop ups at all besides Pinions and Spurs but thats it. Sorry guys But Im getting a GT4-Pro hahah The REason is I want to try something Else but Ill be Running Both Cars. (Most Likly the NTC3) but will see what happens
Yokomo_King is offline
Old 03-23-2003, 04:47 PM
  #2922
Default engine tuning issue with the ntc3 pipe.
does anybody have engine tuning issue on a NTC3 pipe.
engine: nova 5 port
pipe: AE Duel chamber
fuel tank: stock upgrade
issue:
1) engine cut
2) symptom of richness ( lots of smoke but engine over heating)
3) cannot idle for long
4) takes a long time to be on the pipe
5) responds is bad.
issue solved using mtx3 with a nova 1 piece pipe.
1) engine running perfectly
2) ideling for 30sec is nor
3) better responds
4) engine does not cut
5) engine temp is very good.
so it must be the pipe.
is there any solution?
please assist
fuse01 is offline
Old 03-23-2003, 06:02 PM
  #2923
Im having problems im not sure if its my controller or my Throttle servo. Ok Well when i give it break theres a 2-3 second delay b4 the brakes act and then its a hard STop, Im Using a Futaba 3003 Servo I know it sucks im just waiting for my servo to get fixed. so let me know what it could be
Old 03-23-2003, 06:34 PM
  #2924
Check ur transmitter and makesure everything is @ 100...
simonfdr is offline
Old 03-23-2003, 06:49 PM
  #2925
mugen_kid's Avatar
Default Re: engine tuning issue with the ntc3 pipe.
engine: nova 5 port
issue:
1) engine cut
5) responds is bad.
3) better responds
please assist
Hi fuse01
i live in australia queensland i was racing yesterday and i had the exact same symtoms as i was always trying to keep it tuned right i had to pull out for the day and i was quite annoyed and my motor runs in my mugen perfect so at this stage im goin to ditch the car.
