Rc10ntc3
#2761
Freeing Up The Drive Train
Freeing up your drive train. i'm doing that now. polish the insides of the trans cases where the bearings ride. i took the shims off the front and rear diffs the trans runs smooth now, and yes its with the input shafts there. clean all the bearings and for the out drive bearings remove the inner shields. same with the diff bearings. use real light oil to lube the bearings. oh yea and make sure your two speed is lubed and not dragging. i.e. adjusted right. but with the diffs i'm running a spool in the real and a oneway up front. Impact style. just take your time and everything will be sweet in time. Keeping it that way is a task too
#2762
sirio 5 port .12 outlaw
just wondered what other people who might own this engines needle settings are? mine does not seem to want to get to full throttle cleanly with out the high speed needle being 4.5 turns out, seems really rich and ive even fouled a plug with only 8 tanks through. im using novarossi c6tgf hot turbo plugs, trinity 25% nitro, motorsaver air filter, and i live in colorado its about 50 -60 degrees right now. any suggestions?
#2764
Re: sirio 5 port .12 outlaw
#2765
how can u tell if an engine has an air leak? can i use my la crosse infrared thermometer? whats the silicone sealant u guys are using to seal it? where do I have to place the sealant? Im asking these coz I have hard time tuning my os12tr. My ntc3 has idle but after running it for 5 mins my car starts to move without me pulling the trigger on my remote. I did try to adjust the idle speed screw but my car keeps on moving. Pls help me out
#2766
well see where the fuel leaks at thats how i tell if it leaks or stuff
#2767
WEIGHT BALANCE
Does anybody out here know how or what is the optimum weight settings for each corner of the ntc3, also front rear %, total weight etc etc
thanks for all replys in advance
#2768
Re: WEIGHT BALANCE
#2769
ALREADY
hoping second time around will get some help,input,advice etc
#2770
Re: ALREADY
#2771
WEIGHT BALANCE
Well do you mean the springs? shock oil and stuff?
no i`m ok with all this stuff.
It`s when you put the car on scales, you know front weight, rear weight,etc etc
Not viscosity weight.....POUNDS & GRAMS weight
sorry for the confusion
#2772
These weights vary with your set up from harder to softer suspension settings.
Just get both left and right equal. Simple is better.
#2773
I think he means how much should the car be weighing. I think it all varies. A Stock NTC3, I believe is 3.75 Pounds. Mine is currently 4 pounds. Another thing, I think the left side (engine side) should be heavier due to the fuel and the engine. I don't think electronics are as heavy as those two.
#2774
#2775
NTC3NUT
Is that red box by your reciever box a fail safe? If so what kind is it. My NTC3 RTR is supposed to get here tomorrow and this is my very first R/c car. so i am new to r/c. and i am looking for a failsafe to use with it. Can you give me any suggestions on what failsafe i should use? Also doesnt the NTC3 RTR come with a throttle return spring?
Any help would be great!!
Thanks,
David
