Like Tree2Likes
Losi XXX-S
Old 10-15-2002, 11:09 PM
  #4111
Sigearhead's Avatar
Trader Rating: 74 (100%+)
PaulP:
Go to TeamLosi and you will find a downloadable users manual and a part list sheet. You can print it out or just use it as reference. There are many setup sheets including carpet setups for you to look at in their site. Also if you go to Trinity you can find the entire Matt Francis line for the XXX-S.
Hope this helps
Sigearhead is offline
Old 10-15-2002, 11:58 PM
  #4112
Big Pete's Avatar
Originally posted by proudwinner
LouisB, running the pack forward, rearward or split is more of a steering issue. Forward gives more steering while rearward gives less. Split would be inbetween. I've always run my forward.
Hmmm.... I find that if I run the battery forward it understeers like mad, if they are to the rear I get a more neutral feel. Running blue springs all round with 50wt oil. Any ideas or is it just my driving style? I used to run my TC3 the same and I seem to remember from my rallying days that more forward weight meant understeer.
Someone tell me why
Later,
Pete.
Big Pete is offline
Old 10-16-2002, 07:01 AM
  #4113
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Pete, my guess is with the battery forward we already have the weight on the front of the car. When we put the battery in the back the weight transfers towards the front thus giving you the feeling of more steering when off power or braking.
I haven't tried it on the track yet but that is my guess. Of course, all other things will have to be the same and the only thing you change is the position of the batteries.
Kraig is offline
Old 10-16-2002, 07:23 AM
  #4114
ausracer's Avatar
sigearhead, in the setup you posted you said both the front and rear arms are spaced forward. does this mean the wheelbase is the same as stock, if so what is the reason for doing it.
ausracer is offline
Old 10-16-2002, 08:51 AM
  #4115
LouisB's Avatar
Thanks for all the info on battery placement, I'll have to do some testing.
LouisB is offline
Old 10-16-2002, 09:52 AM
  #4116
Sigearhead's Avatar
ausracer: moving the arms forward in the front adds stability while moving the rears to the front gives you more forward grip and you get more steering going into the turns off power. Having the arms forward just gives you better steering all the way around from my experience and the car just seems more planted and carries lots of cornerspeed.
You can just run the arms spaced standard also, that setup will work great either way.
Old 10-16-2002, 10:05 AM
  #4117
Super Moderator
Kraig's Avatar
For those that inquired about the Aluminum Bottom Chassis Covers they are now on the website on the main page, KT Hobbies.
Kraig is offline
Old 10-16-2002, 10:43 AM
  #4118
RCTech Member #2
TSR6's Avatar
Kraig - they are .002 oz lighter than the graphite cover if i remember right.
TSR6 is offline
Old 10-16-2002, 01:17 PM
  #4119
Cain's Avatar
Trader Rating: 294 (100%+)
how much is shipping using priority mail? how do I select that option on checkout?
Cain is offline
Old 10-16-2002, 01:35 PM
  #4120
Super Moderator
Kraig's Avatar
Priority is 4.30 because I use delivery confirmation.
Unfortunately, our shopping cart is not smart enough to handle that kind of shipping so I manually make the adjustment when your c/c is processed. We do not process your c/c until your order is ready to ship.
Or you could just call me with the order as well.
Kraig is offline
Old 10-16-2002, 01:37 PM
  #4121
ttr
ttr's Avatar
Default Spring rates?
What is the spring rate for the Trinity Purple Congo and Blue springs that are used in the foam carpet set-ups?
//I have collected spring tables for HPI , Associated, Xray, Losi but sadly can't find a table for Trinity, and because I can't buy here Trinity springs I must find some similar HPI or Xray springs//
ttr is offline
Old 10-16-2002, 01:39 PM
  #4122
LouisB's Avatar
Here's my Losi, more pics to follow here
LouisB is offline
Old 10-16-2002, 02:16 PM
  #4123
yellow .070,
purple .065,
blue .060
ErikF-Fike is offline
Old 10-16-2002, 04:31 PM
  #4124
TLRacing
Todd Hodge's Avatar
Thumbs up
ttr-Blue-30lb, Purple-35lb, and Yellow-40lb.
Ray-I would try going to 60 pistons in the front with 50wt. I remember that being a huge change on the cars last year at Cleveland. It prevented the car from dumping over the front. To help your car on the exit try moving your rear arms and front arms all the way forward. This will help the forward drive issue that you are having.
Todd Hodge is offline
Old 10-16-2002, 06:01 PM
  #4125
Did most of you guys change to the XXX-S from the Street Weapon? If you ran a different brand what made you decide to try the XXX-S? I am just starting in touring (I am an avid off-road racer) and got a sweet deal on a pair of IWC Street Weapons, but I noticed that everyone seems to have jumped ship on that car. Is the new one really that much better? As a touring noob, would I really notice it, or should I learn with the Street Weapon and move up later on? Thanks.
Action-RC.com is offline
