Losi XXX-S
#4127
i used to have a 414m(for keeps) and have another 04r running now with my 3xs.
in terms of tuning,the 3xs is as good as the 414m,this is where the 04r is lacking.
not tat the 04r is not gd,but these r 2 complete different level cars...
the 3xs felt gd and stable compare to my 04r,...but feel tat my 04r had a harder acceleration compare to the 3xs...
jus my feelings,....
feelings,...nothing more than feelings...
#4128
I would try going to 60 pistons in the front with 50wt. I remember that being a huge change on the cars last year at Cleveland. It prevented the car from dumping over the front. To help your car on the exit try moving your rear arms and front arms all the way forward. This will help the forward drive issue that you are having.
I have front and rear arms forward already and liked that change, but my car still over rotates on exit. I wonder if thats too much exit steering for ME in stock. Its just might be a preference thing. I am going to take out the neg. kick-up on that car next practice session. If its becomes too aggressive again on turn in, I'll run a stiffer front spring or play with Caster some more.
I have my Mod Losi car set-up with the negative kick-up in front and I know thats gonna help as that car pushes out on exit (as mod cars will do!!).
Thanks Todd,
Ray
#4129
ray- try reducing rear droop.
#4130
Does anyone have....
the new part numbers for the new rear shock tower and other updated parts? I read in the new Graphite plus edition it comes with the new updated parts. Any pics would be nice also. Thanks.
#4131
Super Moderator
No new part numbers as of yet.
I do believe that the rear shock tower will be a running change so that means no part numbers. The same can be said for the rear arms. The rear hubs on the other hand will have a new part number. Todd H. believes they should be available around the Cleveland race.
Just wanted to let everyone know that we got in a shipment of Losi XXX-S parts. We are also expecting more in next week (they have to ship cross the country).
Highlights include the Aluminum Dog Bones, 6 degree blocks. Stop on over and take a look, KT Hobbies.
#4132
carbon shock towers
this has got 2 be the koolest carbon shock towers for ths 3XS.
from PRP...
take a look at the hole available for tuning,...no less than the Xray T1 evo2!!!
from PRP...
#4133
I have a set on my car!! They are sweeeeet! Ran them all last weekend with no problems. Gonna try some new camber positions this weekend. They are a great addition.
#4134
u know where i can get them online and pay through credit cards???...i'm having trouble finding a website which allows mi to do this...btw,wat does PRP stands for?...
#4135
Are the Losi threaded shock bodies good enough? Why it seems that many people are using shocks of other rc cars? Do they really leak (loose oil) a lot?
#4136
Shocks
My rear shocks are quite good. For some reason my front short shocks with Nitride shafts build beautifully then the next day-squeek, squeek!!! I dont know why??? Some friends with XXXS report eame issue with front shocks. But there is no evidence of leaking oil anywhere.
Weird , eh?
Weird , eh?
#4137
My shocks definitely leak air. They don't leak oil, though. I usually just stick them in the shock pump and top them off before each race day and they are fine.
#4138
The losi shocks are designed to have some air in them. If they did not have air in them, then it wouldn't compress. When you first build them, yes they might not have air in them. They will pull air around the seals, as when you first build and bleed, they will have a vaccume in the shocks. Then when it equalizes, thats when you have a ''perfect shock''
#4139
does anyone know if losi made a composite or graphite low roll adapter for xxxs losi? please post the part number if there is one.
thanks
thanks
