Losi XXX-S
#4861
Kraig, cool I'll be giving you all a call soon then! Do you know when you will get more yellow belts in and the new shock towers as well? That way I'll just order everything at once.
Thanks!
Jits
Thanks!
Jits
#4863
IMPACTPLAYR - The shock stance of the rear shock tower is much wider than the front tower. And you will run into problems with the shocks hitting the castor blocks if you try the run a wider shock stance in front
#4864
Originally posted by Doug Gaut
Question for the foam/carpet guys. Have you ever been to a carpet track that really does not have much traction? The plaids and purple provide a good balance but the car has an on-power push and feels lazy in the middle of the corner. This is with the Cleveland setup from this year. Any suggestions to get the car hooked up better without changing the tires to cyan/magenta since I cannot find any? BTW, I was using losi black springs. Tried TC3 purples but the car floated too much. Before anybody says, "why dont you just keep testing", keep in mind that the closest carpet track is 2 1/2 hours away and they are having a trophy race this weekend. I would like to try and nail a more responsive setup to finetune during quals. Thanks for the help!
Check your email, if nothing send me your email address to [email protected]
Mark
#4866
Jeff Werner,
Are you running your Losi on Foam and carpet right now? If yes-shoot me an e-mail and lets compare set-ups. Mine is very close to being great for me. Its actually stupendoulsley easy to drive right now, but isnt carrying enough speed-but I think I solved that with a small change!!! I'll test that soon!!
Ray
[email protected]
p.s. not to divert again-but my Rev.3 was totally dialed last Sunday!!! Two Stupid, stupid mistakes kept me from putting it A3 in qualifying.
Ray
[email protected]
#4867
impact....sorry, the towers ARE different, infact so different that the rear wont mount on the front, .....and then dave allready said the rest...
dave, did you figure the takeoffs out yet???? i found a prettygood setup...if you want some help....
see you thursday,
matt
see you thursday,
matt
#4868
Super Moderator
Thanks!
Jits
Thanks!
Jits
Sorry gang, I didn't get the lunsford stuff up yesterday but it is up there now.
#4871
i got some problems with my XXXS GP. when i corner, i hear this clicking sound from the front. i put the car on the stand to see whats wrong and found out that the wheels are shaking heavily. when i turn the EPA down its gone but im not having enough steering when i turn the EPA down. someone help!
#4872
it's some sort of binding problem on the CVD...
try moving ur A-arms 1 spacer forward or backward,tat should solved ur problem...
#4873
If it's clicking I suspect that the CVD pins are sticking out one side a little more than the other. There is barely enough clearance. You can grind off the excess pin with a dremmel with no damage if you are careful. You can do this on the car.
The shaking on the stand at large steering angles is more or less normal on the Losi. Can't be eliminated. Does not seem to be a problem on the track.
#4874
Seems Losi still has some fixing...
to do or I guess they can ignore us.
#4875
There's nothing to fix, you just gotta build it right... I've had my G+ for about 6 weeks or so, didn't have any problems building it, and haven't broken anything...
Ray- I'll give you my carpet/foam setup to compare. I don't have it with me right now, but you can send yours to: [email protected]
