T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 06-14-2012, 06:39 PM
  #8941
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by 1shnot
Has anyone tried ex gear diff on original photon?
Fits!
hanulec is offline
Old 06-30-2012, 02:21 PM
  #8942
yogii's Avatar
Does anyone know if A Main Hobbies plans too carry the EX version of the Photon. I know they have the USA spec, I got that one from them at the end of last summer. I like to get the EX version to run in another class. At this time I have no intent on giving up the version I own.
Question on the older or USA spec, how do you stop the spring nuts on the coil shocks from backing up on you while you're running? I run a Serpent on-road nitro and I don't be-leave I have ever had and issue with them backing up. ALso I have never seen so many screws loosing up on me, as I have notice in the last two races I have enter. Do you use "blue" lock-tite on all your screws. I had my left front wing loosen up. A screw ware I had to stop running because my cars steering crank got hung on screw backing out. I know you have to check your car in between races. But it seems a bit more. No deferent then my "arm" on my steering serval. The screw if I don't check it every time I will loose my arm. (Yes on my steering serval I'm running aluminum arm.) Hey I like to bull#### while out racing with my friends. I like to say I do this as means of entertainment. But I think we all do "no".
yogii is offline
Old 08-03-2012, 10:36 AM
  #8943
Trader Rating: 74 (100%+)
I just bought a used photon,it has a gear diff in the rear what weight fluid would you recommend,i will be running 17.5 on carpet,thanks
steve eaves is offline
Old 08-03-2012, 12:03 PM
  #8944
Trader Rating: 16 (100%+)
1000 cst
samsking is offline
Old 08-04-2012, 01:03 AM
  #8945
TOP FLIP FLOP
peter. is offline
Old 08-06-2012, 07:07 AM
  #8946
What is the gear ratio of the photon?did not see it in the manual,thanks
Old 08-06-2012, 08:00 AM
  #8947
pmc
Hello
Internal gear ratio is 2.0
Best regards:
Pedro silva
pmc is offline
Old 08-06-2012, 10:30 AM
  #8948
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up TOP Photon!!.....
...... Just love this car!!
Kwikvdub is offline
Old 08-06-2012, 08:31 PM
  #8949
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Loving this car too. Raced it for the first time yesterday. Totally stock Photon. And I qualified 3rd in the 17.5 Sportsman class. Running on old 5000mah 40C batteries and a Tekin Redline motor.
Held 2nd place in the main until I got taken out by a backmarker on the very last lap. But I'm seriously down on power. The car was fantastic but some of the other cars just seemed to have more acceleration and top end than I did. The car is so easy to drive fast!
Dan is offline
Old 08-06-2012, 10:05 PM
  #8950
scribbler's Avatar
Is parts support for the TOP cars strictly from overseas of do they have a north American distributor?
scribbler is offline
Old 08-06-2012, 11:47 PM
  #8951
bkspeedo's Avatar
Great support in NA
TOP USA
[email protected]
650-583-8898
You'll talk with Michael O'Donnell, there located in San Francisco, CA
You can also find parts and kits at
Amain Hobbies
http://www.amainhobbies.com/
TimeZone
http://www.timezoneracing.com/store/
bkspeedo is offline
Old 08-12-2012, 07:13 PM
  #8952
wayne breault's Avatar
Need Help I just bought a TOP aluminum spool do I need to run blades on the dog bone for the front? Or do I just put the dog bones into the del rod out drive? Thanks
wayne breault is offline
Old 08-12-2012, 09:01 PM
  #8953
hanulec's Avatar
Delrin outdrives- no blades
Steel outdrives- no blades
Aluminum outdrives - need blades
hanulec is offline
Old 08-14-2012, 05:42 AM
  #8954
Is there another option for a gear diff,i have the light weight and says to run stock only?thanks for any help
Old 08-14-2012, 06:30 AM
  #8955
Bishop's Avatar
TOP made a new gear diff for the EX that will work on any Photon, it should handle mod or whatever you need it for, and it retails for around $30 or so.
Bishop is offline
