T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 08-14-2012, 07:59 AM
  #8956
Trader Rating: 74 (100%+)
Thanks do you have the part # or know where i can order it from?thanks again
steve eaves is offline
Old 08-14-2012, 08:12 AM
  #8957
Bishop's Avatar
http://rcmarket.com.hk/product_info....ducts_id=13331
Bishop is offline
Old 08-14-2012, 09:54 AM
  #8958
Trader Rating: 17 (100%+)
Or just email TOP racing. They should be able to get it to ya in a couple days.
Mr.A Morris is offline
Old 08-14-2012, 10:50 AM
  #8959
odpurple's Avatar
Gear Diff Set Part # PO-PDT101
[email protected]
650-583-8898
odpurple is offline
Old 08-14-2012, 11:25 AM
  #8960
wayne breault's Avatar
Need Help! A while ago I bought a Titanium spool from TR. I need to change the derlin out drives. I emailed TR they said they don't have them anymore. Does anyone know where I can get them I need 6. They are especially made so any other out drive won't fit. Thank you
wayne breault is offline
Old 08-24-2012, 12:37 AM
  #8961
hey guys, just a random question, i am missing my left rear wing
i will be replacing it with the carpet edition but that will just be a temp fix for now. Does anyone know where to source this from as our local Distributor doesn't seem to have it :-(
Menace84 is offline
  #8962
double post, my bad.
Menace84 is offline
Old 08-24-2012, 07:31 PM
  #8963
odpurple's Avatar
If you are in North America:
[email protected]
650-583-8898
odpurple is offline
Old 08-24-2012, 08:16 PM
  #8964
MikeXray's Avatar
Trader Rating: 73 (100%+)
If memory serves me the carpet wing is the same thickness, you can just dremel off the extra part of the wing.
MikeXray is offline
Old 08-24-2012, 10:06 PM
  #8965
no worries, i was going to trim down the carpet one until i found the correct replacement, im particular like that haha, but on a better note, i live in australia, i found them on A-main last night. thanks guys.
Menace84 is offline
Old 09-04-2012, 03:50 AM
  #8966
Hi Guys , just a technical question ? If I may . I have just recently bought a 2nd hand Photon and have been trying to tighten the pulley belt . One of the top deck screws is stripped and I cant get the plate off . Is there any special method that you can suggest to get the culprit loose ?
robprid is offline
Old 09-04-2012, 06:40 AM
  #8967
Skitee's Avatar
Use a dremel to put a slot in the screw head then use a flat screwdriver to turn the screw out.
You don't need to loosen then top deck to adjust belt tension, is it one of the camber plate screws that you are talking about.
Skitee is offline
Old 09-06-2012, 12:06 PM
  #8968
Thanks Skitee . Managed to lightly tap a torque Bit into the stripped screw and then unscrewed them . Man I am enjoying this car
robprid is offline
Old 09-18-2012, 11:31 AM
  #8969
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Exclamation Looking for....
Hello, Anyone out there have a brand new "EJ Evans TOP Photon LiPo chassis!"..... LMK.....
Thanks!
Kwikvdub is offline
Old 09-22-2012, 07:55 PM
  #8970
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Thanks!
Did you try our TOP buds ?
j.d.roost is offline
