Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 03-03-2009, 08:30 AM
  #8941
chrisfrom619's Avatar
Originally Posted by speedsterblade
Are you getting any specific flashing on the GTB after it stops? I had a similar problem but had 8 or 10 flashes after it stopped. I had to have it replaced.
Yes the red light is flashing I just turned it off. Which one did you replaced the GTB or the Motor.
chrisfrom619 is offline
Old 03-03-2009, 11:23 AM
  #8942
speedsterblade's Avatar
it was the GTB I had to replace....
speedsterblade is offline
Old 03-03-2009, 10:16 PM
  #8943
Team STPN's Avatar
Originally Posted by Josh Hohnstein
Sorry but I just about never use a scale.
But when I do check the car it goes in this order:
set ride height at all 4 corners
check camber
set droop
check tweek
The scales are probably a good idea for the first time set up for weight placement. But i've just gotten used to doing it with out them.
Hey Josh,
Quick question for the .5 & 1 mil axle spacers. Where do you them??
Team STPN is offline
Old 03-04-2009, 05:09 AM
  #8944
Trader Rating: 3 (80%+)
Originally Posted by Team STPN
Hey Josh,
The ones I use are sold by tamiya but im sure alot of companies sell them. I'll see if I can find some part numbers.
Josh Hohnstein is offline
Old 03-04-2009, 08:44 AM
  #8945
berserk's Avatar
is anyone using front body post from other brands? the front post included in the kit seems short. thanks.
berserk is offline
Old 03-04-2009, 09:03 AM
  #8946
balistic's Avatar
Trader Rating: 113 (100%+)
check camber
set droop
check tweek
I was looking at this and wondering why not do the fixed adjustments first?
Droop
Camber
Ride height
tweek
I was also wondering if stiction is measured as a component of ride height?
Another way of asking that is do you measure ride height from where the car settles onto the springs or where it rebounds to
balistic is offline
Old 03-04-2009, 10:50 AM
  #8947
Droop
Camber
Ride height
tweek
If you try to set your camber while your ride height is off you will have some pretty messed up camber settings when the ride height is set correctly.
Old 03-04-2009, 12:58 PM
  #8948
balistic's Avatar
Ok then, so the ride height sets the position of the wheels (1) then the camber (2) The droop only changes the drop out of the suspention. I get that, I was thinking droop effected the position of the wheels, but the suspension is in sag.
What about the stiction question? Is ride height measured from the car rebounding of bottoming?
balistic is offline
Old 03-04-2009, 04:49 PM
  #8949
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
They really are not that short unless you are using a body other than a sedan.
Kraig is offline
Old 03-04-2009, 05:50 PM
  #8950
Team STPN's Avatar
I would appreciate that..thanks..
Old 03-04-2009, 06:35 PM
  #8951
Jerry P's Avatar
Trader Rating: 44 (100%+)
They do seem kind of short when running a Mazda Speed 6. Roof height is set to pass roar tech inspection. I am running the top most hole on the body post. On my foam car with a Mohawk 2 the front post's have plenty of space.
Jerry P is offline
Old 03-04-2009, 08:02 PM
  #8952
STLNLST's Avatar
Trader Rating: 32 (100%+)
53646 is the part number you might be looking for from Tamiya LXFSD2 is the tower part number. These may be on my car on the 14th if we dont get rained out.
STLNLST is offline
Old 03-04-2009, 08:17 PM
  #8953
theDover's Avatar
Gearing help please.
Running a 5.5 BL on an outdoor asphalt track 120' x 60'.
Any suggestions with pinion/spur to start with would be appreciated.
theDover is offline
Old 03-04-2009, 09:17 PM
  #8954
Team STPN's Avatar
Can you get me .5 and 1 m spacers?? I promise i will not use your name in vain
Old 03-04-2009, 09:25 PM
  #8955
STLNLST's Avatar
STLNLST is offline
