Team Associated TC5
The solution is to get rid of the angle in the link, by using another servo horn or moving the servo out.
If it's not biding though and you get full steering throw in both directions then I wouldn't worry about it.
Regards
Neal
Yeah, I get zero binding. It is one of those things(among several things) that just bother me when I look at it, but have no real ill affect on performance.
--pakk
--pakk
Tech Legend
Trader Rating: 51 (100%+)
Cool, I assembled the spool for the next race, I always mix my tires up so chances are they've been on each wheel, also I was looking at the manual and when I was installing the axle shims I didnt see the part that said 2 for each axle and only installed 1 on each side so I was getting strange camber readings...
Tech Legend
A friend of mine recently got a TC5 and didn't have the right servo horn for it. The steering link ended up at an angle, exactly like it is in your picture Pakk. If your steer it with the transmitter it seems ok, but if you turn with your hand there is a serious binding if you steer right a lot. I tracked it down to the ball on the servo horn binding on the cup.
Regards
Neal
Regards
Neal
even if its not binding the servo still has to work a little harder to make the car turn at high speeds.
Needing some help with cams and belt tension. My kit came pre-built so I am sort of going backwards and making appropriate changes.
According to the setup it is setup up with cam A tension front 3 rear 30.
Now I am still new to the tc5 but from what I see they look like cam B with holes in them. Someone correct me if I am wrong here so even though the setup calls for cam A looks like cam B was installed.
I am running a 17.5 brushless and hoping someone can point me in the right direction of how tight/loose the belts should be.
Also having a bit of a hard time reading the tension numbers. I'm looking at the manual and starts 17 from left to right 32 what increments are being used to read the numbers?
Is your belt tight? The manual indicates how to read the tension numbers. I just tinker around with them until the tension is how I want it. Be sure that you have both cams positioned in the same direction.
If you are only running 17.5 or 13.5, you will want to set your belt a bit loose.
One more thing, was the car run quite a bit before you purchased? The belt will need to be worn in a bit so that it can stretch naturally.
Belts look good but than I don't have new ones to compare but they don't look warn. I am looking over the manual but maybe I am a bit lost.
Turned upwards reads number 1-16
Turned downwards reads 17-32
So do we read 17, 18 .... 32 becuase if so it just doesn't jive. So either we are doing 17, 20, 23 etc..
belts are not tight.
The different cams are to change diff height. This will change the feel of on/off power differences.
As far as how tight:
Adjust so that you have minimum resonance. Easiest is to give the car full throttle and listen to the revs. Tighten until the revs start to drop. I myself changed the the Team Bomber belt which has helped quite a bit.
--pakk
Yes, you can hear your rpms drop if your belt is too loose or too tight. This is while freewheeling with a 13.5. Im not overly worried about a 13.5 grenading while freewheeling, though I do have the tires on while doing this. (Also using an SPX so the RPM does go quite a bit high.) Again, just watch for belt resonance and listen for the revs to drop. This is also track dependent. Say your only 10% full throttle on one lap, then you can afford to lose straight line speed. Adjust the belt tension so the belt resonates at different RPMs. Again, I am using the Team Bomber belt that is quite abit freer.
Hey Guys,
Looking to get a low profile and lighter servo into my TC5r
Looking at the KO Propo PDS-2413ICS
or Futaba S9551.
Any fit issues or performance?
Thanks alot and God Bless
or Futaba S9551.
