Xray T1FK05
#3151
For high traction tight tracks a 25t pinion will gain you more through the infield.
#3152
Originally Posted by dado11g
anodizing adds pretty much no material, this is b/c it is just corroding and not the adding of material. anodizing is controlled corrosion on the outer layer of the aluminum.
#3154
larrys or the street
#3157
Originally Posted by teamgp
Hows this for concealment and tidyness?
Its zip tied to the back of the bulkhead, it works and hard crashes haven't affected it.
Before, I stuck it on top of my servo as well. But I found that the front balanced out better with it on the right side of the centerline.
Hope that info helps some!
Jason
#3158
I had some 1/8th lexan so I ended up making a piece so I could hang it off the servo....
#3160
Building the shocks does SUCK! Fortunately, I found an easier way of doing it! I bought this locking shock shaft pliers from teamtamale.com and let me tell you it REALLY made life easier for me! Building shocks is now a breeze! Only $25 too!
Shock pliers
Shock pliers
#3162
For bleeding the shocks I used the Tamiya shock vaccum tool. I can't remember the part number but it REALLY helps with bleeding shocks. It was a bit expensive though. It's nice to have but not necessary. I just did mine very carefully by moving the shock rod up and down ever so slowly until all the bubbles were out.
#3164
jr z8800s
#3165
atomic, you sound like a TV infomercial....
