Like Tree1Likes
Xray T1FK05
Old 10-06-2005, 06:44 PM
  #3901
1armed1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by hpipro321
Make sure you have those black things inside the bulkhead in the corasponding spots
hope it helps
Amish
Also there is 2 pair of the eccentric bushings, make sure you are using matching ones.
1armed1 is offline
Old 10-06-2005, 06:45 PM
  #3902
S-T-R-l-K-E-R's Avatar
Originally Posted by Chris08527
hey guys
putting together my first FK05, one prob
my rear diff is sitting unlevel in the bulkheads, i know something is in backwards or upside down but cant figure it any
any suggestions???
the kit comes with 4 black plastic holders for the diffs. 1 pair to set the diff low and 1 pair to set the diff higher. you must have used one of each on your car.
S-T-R-l-K-E-R is offline
Old 10-06-2005, 07:15 PM
  #3903
hpipro321's Avatar
thats wut i was trying to get at
hpipro321 is offline
Old 10-06-2005, 07:34 PM
  #3904
cool great minds think alike!!!!
Old 10-06-2005, 08:02 PM
  #3905
centax error!'s Avatar
guys, I got a quick question: what's the biggest 48P and 64P spur that will fit on the optional 2 mm chassis?
Tnx
CentaX
centax error! is offline
Old 10-06-2005, 08:04 PM
  #3906
CE - im guessin around 114T 64dp
Old 10-06-2005, 08:09 PM
  #3907
for 48P...it will be 86T
tsuiyuen is offline
Old 10-06-2005, 08:28 PM
  #3908
Rob pacheco's Avatar
64 p 118 no modification
Rob pacheco is offline
Old 10-06-2005, 08:39 PM
  #3909
Regional Moderator
BHenderson's Avatar
Does anyone make a foam car stand for the FK05?
BHenderson is offline
Old 10-06-2005, 08:41 PM
  #3910
Striker/Rob/Tsuiyuen : Thanks!
btw, has anyone tried the adjustable upper deck running spool yet? did it help improve the steering? Im using the stock upper deck and still can't get rid the mid corner push
CentaX
Old 10-06-2005, 08:51 PM
  #3911
howard hudson's Avatar
P DUB makes this universal one. Kinda cool holds shocks and a battery if you need to work on them click me to check it out
howard hudson is offline
Old 10-06-2005, 11:35 PM
  #3912
mid corner push?
that related to your setting bor....
adjustable top deck really a gd stuff...
easy to change the stiffness of the chassics...
and it affect the car's handling much...
by the way..i am still in the way testing spool + adjustable top deck..
maybe share my experience next wk after i have a try...
tsuiyuen is offline
Old 10-07-2005, 01:41 AM
  #3913
Spud_J's Avatar
Tnx
CentaX
64dp 118 will not fit with the 2.0mm chassis, only with the 2.5mm. A 118 will hang out the bottom of the 2mm chassis.
For 2.00mm chassis the biggest are 64dp 116 and 48dp 87.
Spud_J is offline
Old 10-07-2005, 05:46 AM
  #3914
ah ok...thanks Spud
Centax
Old 10-07-2005, 06:17 AM
  #3915
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
hope it helps
Amish
Thats exactly what it is. I did the same thing..
HRCRACER123 is offline
