Like Tree1Likes
Xray T1FK05
Old 08-11-2005, 11:50 AM
  #3166
Originally Posted by vtl1180ny
atomic, you sound like a TV infomercial....
Hehe...I guess I do. What can I say, I love tools that simply works! And no, that wasn't a quip either.
atomic80 is offline
Old 08-11-2005, 01:50 PM
  #3167
teamgp's Avatar
Originally Posted by BigDogRacing
TeamGP- I'm not saying your PT won't work cause I'm sure it is/does, but numerous tests both by our club and others including AMB testing have shown the number of hits the decoder sees with the PT mounted vertical instead of horizontal is much less. I wouldn't suggest anyone mount their PT like that...
I had heard of there being problems, but I tried running it verticle in a cutout section of my front bumper with the fk04 and I never had any problems on three different tracks. I haven't had any problems with it being vertical behind the bulkhead either.
But hey, I cut my spektrum receiver wire to 3 1/2" and I've never had a problem with that to.
teamgp is offline
Old 08-11-2005, 01:55 PM
  #3168
teamgp's Avatar
Originally Posted by jamescam
I almost picked that up but I'm not having trouble getting the ball ends on, my problem is bleeding the shocks. Does this tool help with that?
If you follow the instructions at this link, you'll never have bleeding problems again and I won't charge you anything either.
teamgp is offline
Old 08-11-2005, 01:58 PM
  #3169
jamescam's Avatar
You tease, no link!
jamescam is offline
Old 08-11-2005, 02:14 PM
  #3170
teamgp's Avatar
You tease, no link!
Doh! My bad.
http://www.teamxray.com/xforum/viewtopic.php?t=602
teamgp is offline
Old 08-11-2005, 02:41 PM
  #3171
jamescam's Avatar
And see there I thought it would be difficult to get them right currently on step 4 of 82
jamescam is offline
Old 08-11-2005, 05:15 PM
  #3172
TeamPink91's Avatar
My thoughts exactly, which is why I'm buying tamiya shocks.
TeamPink91 is offline
Old 08-11-2005, 09:50 PM
  #3173
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Can I get some feedback on people running Tamiya shocks? Good and Bad
Kennedy is offline
Old 08-12-2005, 05:11 AM
  #3174
work's Avatar
Tamiya shocks are the best shocks IMO but xray shocks can be as good if built the right way
work is offline
Old 08-12-2005, 06:57 AM
  #3175
Andrew_Carter's Avatar
You lot are beaten to easily! Carnt build shocks so you buy idiot proof Tamiya shocks!
Xray shocks are fine! you just have to find a method of building them that works! Mine is nothing like TeamGPs but it works for me!
Andrew_Carter is offline
Old 08-12-2005, 10:50 AM
  #3176
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Hey guys. I run my car on low bite carpet with foam tires. What would be the best starting point as far as droop. I dont use the gauge. I set it by using the millimeters above ride height technique. Thanks
HRCRACER123 is offline
Old 08-12-2005, 11:04 AM
  #3177
Default Xray t1fk05
Hey Andrew, I am buying this car and everyone seems to complain about the shocks. What is your method of building these?
Farmers Agent is offline
Old 08-12-2005, 12:34 PM
  #3178
2mm over ride height is were i set mine
goop is offline
Old 08-12-2005, 02:46 PM
  #3179
acutts's Avatar
Hi Guys
What does a spacer underneath the steering arms lifting them a 1mm or 2 above the steering hub do ....? Hope that makes sense...
Cheers
S
acutts is offline
Old 08-12-2005, 03:16 PM
  #3180
axel's Avatar
I'll admit when i first started on the shocks i was kinda disapointed, but once i finally got it right, everything was fine, Ralph Burch said that alot of people just bleed their shocks wrong.
axel is offline
