Xray T1FK05
#1651
Whats stripped? The threads or the screw head?
#1654
Originally posted by John Fontaine
more holes means things are weaker and it would break like a HPI
#1655
Yes the thread on the srew is stripepd not the driver ( i liek titening things too much) i think i will have to drill it out. It will be okay for now tho. i jsudt finished assemblign the forn bulkheads and arms, its lookin good now. Im just worried about the screws
#1656
Originally posted by kewdawg
Actually, I've broken the same items on my Pro 4s, that I've broken on my Xrays: Steering knuckles, C-carriers and bumpers. The glaring difference, is, Hpi makes excellent and very strong aluminum shocks, that are INCLUDED in the kit. You make the call.
Stay away from the walls
#1657
Originally posted by HarshGuy
...here's what I did so I wouldn't have to tape bats in (till the brace comes out!!)
Is it tight enough ?
#1658
LOL
#1659
Yeah, I have the plastic shock bodies on my 05, but have alum shock bodies in my spare parts just in case. I think the shocks are smoother with the plastic shock bodies, but not as bling
WC this Saturday? Thinking I need to try out my Hara V2
#1660
Those guys must be some SERIOUS whammers then...
I should know...because *I'M* a whammer and I do't break anything close to that....
but I'm running a rubberneck bumper
From what I've seen C-Hubs are C-hubs...a sacrificial part on almost any car. If you go to aluminum C-hubs then the knuckles are the next to go..
I think that the arms on the Xray are slightly stronger than most of the other cars I've seen at the track (AE, Losi, Yoke, HPI...can't speak on the Corally or exotics)....If you break an arm on an Xray you KNOW that you had some serious contact.
The upper bumper brace is a HUGE difference maker on the durability of the cars. It is designed to break first. Some people are too cheap to replace it when its broke, and that will spell disaster for them. When the upper brace is broke replace it!!!! The upper brace holds your bumper in place so it can absorb the impact. Glueing the upper brace together after you break it is not enough. It will let the bumper move back into your wheel and risk your C-hubs etc...not to mention end your run. I always keep an extra upper bumper brace or two in my pit box
#1661
Oh Quinn...stop talking about Danny Pawling like that.
#1662
Originally posted by wannabee
Has anyone noticed this car to be loud? The bearings seem to be 89.9999% of the cause...IMO
KE
KE
#1664
#1665
Yerp i loosned both my belts off frotn and rear as a less resistance with teh belts on the pulleys will equal a smoother srivetrain. I found that stock setting on the fornt belt was muchh!! tooo tite.
