Xray T1FK05
#1966
that is what I have done, but I have heard of using a ride height gauge, holding the tire down (on the board), and lifting the chassis to get a second ride height measurement - then subtracting the original ride height from the elevated ride height to figure droop. The Hudy book says to do basically the same thing, only using a ruler
#1967
Measure your ride height at whichever end you are measuring droop. Then lift the end of the car you are working on, and measure the height at which the tires leave the ground. This is droop.
The difference between ride height and the height the wheels left the ground is your droop measurement.
#1970
what weight oil spring and piton combos are being run on carpet . i see like 30 and 35 with different springs on the tc3 tc4 oils are like 50 60 70 .
#1971
also does anybody know where to get the ackerman extensions from
#1973
whats there website
#1974
#1975
nevermind i found it
#1977
Re: 64P gears
Originally posted by B4
Hi,
Looking at changing to 64p pinion and spurs. Do you have a link to a gear chart calculator that caters for 64p instead of 48p.
Hi,
116t 64p is almost the exact same size as 84t 48p if you want to keep it the same.
#1978
Re: 64P gears
Hi,
Hi,
#1979
Re: Re: 64P gears
Originally posted by HarshGuy
It's the same calculation ...go to www.gearchart.com and you can generate a gearchart for your car.
I was going to get spurs 112, 114 & 116 will Kawada fit.
#1980
Re: Re: Re: 64P gears
Yeah I didn't realize that before.
