Like Tree1Likes
Xray T1FK05
Old 04-21-2005, 01:28 PM
  #1936
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
http://www.teamxray.com/teamxray/sho...p?file_id=2039
There you go.
dr_hfuhuhurr is offline
Old 04-21-2005, 04:55 PM
  #1937
Bah...
Just tried to order PRS spur gears... it was going to cost me $20 USD for shipping to Canada for 4 spur gears...
Not worth it...
MartynD is offline
Old 04-21-2005, 06:10 PM
  #1938
NVisible's Avatar
They are good gears, but they are high on the price scale.
I believe great hobbies carries Kimbrough spurs (i hear the 116 64P gear is whats popular)
NVisible is offline
Old 04-21-2005, 06:40 PM
  #1939
S-T-R-l-K-E-R's Avatar
Default Re: Re: Re: Re: Re: Set-Up
Originally posted by =MisFitz= NuKe
Having the arm "kicked-up" like that calms the car down, to me. I did that because the car would get to rear-end happy going into the chicane on our track.
try closing shock pistons front and rear at least 1 hole.
S-T-R-l-K-E-R is offline
Old 04-21-2005, 07:27 PM
  #1940
=MisFitz= NuKe's Avatar
Default Re: Re: Re: Re: Re: Re: Set-Up
...thanks, but thats alright, kicking up the front arms, helps better on our track for that purpose.
=MisFitz= NuKe is offline
Old 04-21-2005, 11:38 PM
  #1941
Shop Owner
nnick's Avatar
Here is another link with X-Ray setups
http://www.rcingreece.com/index.asp?...tups&Car=X-Ray
Nick
nnick is offline
Old 04-22-2005, 12:56 AM
  #1942
Lonestar's Avatar
Trader Rating: 14 (100%+)
Originally posted by Mike Mandio
A post from Mario Hudy on the FAQ section of the Xray site:
mario
Posted: Mon Apr 11, 2005 7:07 am Post subject: I have a dry differential
The differential has been built per factory specifications and this way it has been build for several years by well trained factory assembly staff with great results. The diffs are being build and set-up for ultra smooth operation. All factory team drivers have been using the original diffs without modification or re-assembly which is a proof that the diffs are build ready for any high competition conditions. There is a thin and sufficient layer of grease put on the large diff shims, there is sufficient amount of grease applied on the carbide balls and there is sufficient amount of grease applied on the axial bearing as well.
You will not find any extra amount of grease in the differential because XRAY differential has been build for smooth operation and features only the neccessary, appropriate and sufficient amount of the grease. If a large amount of grease would be applied, this will make the operation of the differential not as smooth and efficient like it is now - built per factory specifications.
Moreover XRAY differentials feature the XRAY Dust-Covers which seals the differential perfectly and no or very minimum of dust can get into the differential. Therefore even a small amount of grease is sufficient to make the differential work smoothly and perfectly for a long time.
Please note that XRAY has been using a very special grease which is very thin and transparent so it may look the differential is dry. XRAY strongly suggest NOT to use any other grease than the original XRAY grease.
To summarize the answer - XRAY differentials are NOT dry. If you do not see any overflowing amount of grease in the differential do not worry, your differential has been built properly with thin and sufficient layer of thin grease for smooth operation of the differential. If you believe you need more grease than is the factory standard, then please use the included grease in your kit but remember that a larger amount of grease may make the differential run not that smooth. You can purchase the XRAY Grease under part number #30 9500 Silicone Grease
At the end, please remember if you want your differential to last long you need to break-in the differential properly. We will add another FAQ section about the proper differential break-in.
Pure BS.
Mine was as dry as a sunny day in the Sahara.
And those e-clips sure are a b!tch to get out.
Paul
Lonestar is offline
Old 04-22-2005, 04:35 AM
  #1943
i just got my fk05 on tues and i'm glad i asked about the diffs because mine are dry to and yes those clips are a pain in the ass even with snap ring pliers .
rcfreak24 is offline
Old 04-22-2005, 05:15 AM
  #1944
HarshGuy's Avatar
..it wa a piece-o-cake with snap ring pliers (I though) ...I did have to dremel the little pins donw though on the pliers as even the smallesst ones I could get at Kragen were to large of a diameter.
HarshGuy is offline
Old 04-22-2005, 05:32 AM
  #1945
komkit's Avatar
Forget the snap ring pliers. They don’t work in limited space.
Here is what I am using
komkit is offline
Old 04-22-2005, 07:03 AM
  #1946
Alright, so I just got the thicker chassis inn from Xray (3.00mm), and I noticed the battery slots look kind of filed, but not all the way??? Are they already cut or do I need to go in and dremel more on the chassis to get the batteries to sit correctly? Also, how is everyone's car reacting with the different roll center due to the areas where the bulk-heads sit, not being machined out?
-Mike
Old 04-22-2005, 07:58 AM
  #1947
Nuke,
Surely you have a battery pack you can put on the chassis to check the fit.... You will have to do that anyways if you have to dremel.
MartynD is offline
Old 04-22-2005, 08:22 AM
  #1948
Originally posted by MartynD
Nuke,
This is true...but I don't have all of my stuff over here, just the box the chassis came in, so I wanted to ask on here...
Old 04-22-2005, 08:25 AM
  #1949
ddesros2's Avatar
Yes, you do need to shave it down some more to fit 3300's flush with the bottom of the chassis.
ddesros2 is offline
Old 04-22-2005, 08:27 AM
  #1950
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Default Reading Set Up Sheets
I have a question about droop vs downstop.
I am trying to learn/figure out the difference in these two things - can someone explain the difference? Also, from looking at the setup sheets from X-Ray, I don't see a "droop" setting, just a downstop - are they counting it as the same thing?
rctoyguy is offline
