Like Tree1Likes
Xray T1FK05
Old 04-16-2005, 07:07 PM
  #1816
centax error!'s Avatar
I don't like a flexible chassis I would work on the inserts or the suspension instead.
centax error! is offline
Old 04-16-2005, 10:48 PM
  #1817
Sluggo's Avatar
Thumbs up
Hi Everyone.....
Just wanted to jump in to say Hi. I just just jumped ship from the Pro4 to the Xray and man I have seen the light! This car is so nice to drive, it almost drives itself. I'm really liking this car. I made a good move
Sluggo is offline
Old 04-17-2005, 12:30 AM
  #1818
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
sometimes a more flexible chassis is better, especially when running rubber tyres.
dontfeelcold is offline
Old 04-17-2005, 01:50 AM
  #1819
JohnMatrix's Avatar
of the 5 people I know that have the car, including me, 3 of us are having horrid glitching problems.
we have seal the chassis, tried removing each component from the car and tested and it just keeps glictching,
what have you guys done if you have this problem
JohnMatrix is offline
Old 04-17-2005, 02:02 AM
  #1820
HarshGuy's Avatar
What kind of electronics you running? ...none of us out here at SWR-land have had any glitching problems (there's 7 of us converts out here).
HarshGuy is offline
Old 04-17-2005, 02:43 AM
  #1821
JohnMatrix's Avatar
hey harsh,
novak 75mph, and a Q2 speedcontrol. on my end.
Old 04-17-2005, 03:25 AM
  #1822
HarshGuy's Avatar
hey harsh,
I'll ask around and see if anyone is running that combo or any of those components ..I'm running all KO electronics (VFS1, 302f, 2343), maybe placement of electronics? I know Scotty had some problems @ SWR and he moved his transponder and problem solved
...my car is perfect in botch stock and 19T at SWR (and was at Gilroy a couple of weeks ago, glitchingwise anywyas ) ...here's a pic so you can see where I'm placing my electronics:
http://www.arroyoc.com/rcracing/harshtopview.html
HarshGuy is offline
Old 04-17-2005, 03:51 AM
  #1823
I had some glitching the last race weekend I attended, all caused by an Epic ROAR stock motor. None of my other motors caused glitching. Just added caps and I was fine. The motor was brand new and I've never run it in another car.
Electronics..
Airt 75mhz synth rcvr
KO 2123 servo
Novak GTX
MartynD is offline
Old 04-17-2005, 06:35 AM
  #1824
komkit's Avatar
Default Re: Aluminum Front Hubs/Axles
Originally posted by RobertV
I would consider the spring steel units to be a mandatory upgrade.
Where would I find them spring steel stuffs in US?
Can't seem to find hobby shop that got them in stock.
I thought I saw one shop got the SS outdrive but I went back and look again it was for one-way
I can get the wheel axle in SS but couldn't find the SS outdrives.
Ran asphalt two times with rubber tries. Distroyed two of the front ightweight outdrive (long size) under heavy braking.
Anyone know where to get the SS outdrive or just solid alu outdrive (I think # 30 5010) please let me know.
komkit is offline
Old 04-17-2005, 07:08 AM
  #1825
Michal101's Avatar
Default Re: Re: Aluminum Front Hubs/Axles
Hey Komit,
I tired to get one a few months ago and I was told that Xray no longer makes the SS diff halves, but I was fortunate enough to find one by posting on the R/C boards.
Michal101 is offline
Old 04-17-2005, 07:41 AM
  #1826
HarshGuy's Avatar
I remember reading somewhere that they don't make the solid au oudrives anymore as they were beeing replaced with the multidiff ( 305012 ) ...I picked up a spring stell diff, but it doesn't seem to be in stock anywhere anymore, here's where I had gotten it:
http://www.thercshack.com/index.asp?...OD&ProdID=2093
HarshGuy is offline
Old 04-17-2005, 08:19 AM
  #1827
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Nice motor in that one...bet that thing is a rocket
dr_hfuhuhurr is offline
Old 04-17-2005, 08:36 AM
  #1828
duckman996's Avatar
Trader Rating: 14 (100%+)
Originally posted by Sluggo
Hi Everyone.....
Welcome to the dark-side brother Sluggo.
duckman996 is offline
Old 04-17-2005, 08:43 AM
  #1829
duckman996's Avatar
Electronics..
KO 2123 servo
Novak GTX
Is this the glitching that caused you to plow into my car?
I run a GTX, an airtronics micro receiver and a personal transponder with no problems ... I actually removed the APS "glitch-buster" items from my electronics and so-far, so-good.
Martin P
Old 04-17-2005, 10:18 AM
  #1830
Sluggo's Avatar
thanks Duckman...feels good
Sluggo is offline
