Like Tree35Likes
Old 08-22-2015, 03:28 PM   #9751
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Originally Posted by nitro2be View Post
+1 out door med. 7/100/3
Should had said it before I'm indoors. Still the same ?
Crazy Carl is offline   Reply With Quote
Old 08-22-2015, 04:42 PM   #9752
13Maschine's Avatar
Send a message via Skype™ to 13Maschine
Originally Posted by RENOV8R View Post
Thanks! Just ordered the hubs and bushings. I've been using the X-Ray bushings, we'll see if these are as good
Keep us posted! I've been looking at the Xray bushings so I'm curious to hear your comparison. Although I'm tempted to just order a set of Exoteks so they arrive as soon as I return from Seattle.
SoCal R/C Privateer, find me at either OCRC or SCVRC!
My JUNSI POWERED Rides: Xray XB2 CE, Hot Bodies D413, Kyosho RB6, HobbyWing Xerun 3.1, Futaba 4PX, Futaba and MKS Servos, Speed Passion Hirosaka and HW V10 Powerplants!
First car Kyosho Pegasus and RC10CE! More than 25 years Racing! Happy to lend a helping hand. Just ask! :)
13Maschine is offline   Reply With Quote
Old 08-22-2015, 07:29 PM   #9753
RENOV8R's Avatar
Originally Posted by Brett C View Post
I took the plunge and bought a kit with all the trimmings! Amain probably knows my address by heart this week. Looking through some of this thread from a year ago, i saw that spur gears were stripping. Is this still an issue or will the exoteck spur and mounting plate i ordered help this? Also, do people prefer specific brand of pinion gear for this car? I'll be running a 6.5 orion. I look forward to many days of fun with this car! I hope it helps my 1/8 nitro driving in the process
I think the spur issue was just a few guys not getting their mesh right, and blaming it on the spur. The Exotec is a nice product, just keep the stock one as a spare. And as for the pinion, I don't think brand makes a difference as long as it's hardened steel, not aluminum. (I find they wear VERY quickly.
RENOV8R is offline   Reply With Quote
Old 08-22-2015, 07:34 PM   #9754
RENOV8R's Avatar
I'm sure anything would be better than the stock bushings. If anyone orders the XRay bushings, take note that you have to order 2, as they only come 2 to a pack. Speaking from experience LOL
Old 08-22-2015, 08:18 PM   #9755
kenny lutz's Avatar
Trader Rating: 36 (100%+)
Yes I run on an indoor clay track
Kyosho Rb6.6- Maclan mmax - Fantom 17.5
Kyosho Zx6.6- Maclan mmax - Fantom 13.5
Airtronics M12 - Auer Ace Hardware - Schelle
kenny lutz is offline   Reply With Quote
Old 08-22-2015, 10:25 PM   #9756
nitro2be's Avatar
I run both and leave same 7/100/3
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 08-22-2015, 10:37 PM   #9757
Congrats in your buy, you will have lots of fun with your car. The spur stripping thing was never an issue by HB. I just took motor clamp screws with a bigger head for a 2.5mm tool and looked carefully on the Spur-pinion mesh and never had a problem. I raced my car for one year now and just 2 weeks ago i replace my Spur and pinion the first time just because both were worn.
I always use Hudy hard coated pinions and like them best over many others. I have the Exotek upgrade and for sure the mesh will be more exact with a machined Spur but when i replaced my old spur i took an HB again because i also read about the problems here and bought some spare Spur gears and want to use them before i put on the Exotek.
Hope this helps
Egress is offline   Reply With Quote
Old 08-23-2015, 04:35 AM   #9758
RC10B4_Mafco's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to RC10B4_Mafco
I had problems with the spur gears stripping, and I think I now know why. Ever since I have ran the grub screw that locks down on the mount that is secured to the motor (when I first built the kit I didn't know what it was for but now I understand why it's there), I have had no more problems with stripping spur gears. This must prevent the motor from moving when the chassis flexes.
RC10B4_Mafco is online now   Reply With Quote
Old 08-23-2015, 07:15 AM   #9759
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
Hey guys, quick question for ya. Going to put shock limiters in so I don't have so much droop, is there a kit or spacer kit I can buy for this? Or do I have the fun of just finding what fits and going with it?
xxx-ntad2 racer is offline   Reply With Quote
Old 08-23-2015, 07:55 AM   #9760
Chr1s's Avatar
Any brand that uses a 3mm shock shaft limiters will fit. There were limiters in the kit I think. Check the manual. Associated will probably be the easiest to find.
Chr1s is offline   Reply With Quote
Old 08-23-2015, 10:35 AM   #9761
SeanKewley's Avatar
For 0 rebound, are you guys pushing the shafts all the way up before closing the caps/ bleeder, or just shy of full compression?
SeanKewley is offline   Reply With Quote
Old 08-23-2015, 12:07 PM   #9762
tom2tone's Avatar
Trader Rating: 98 (100%+)
Hey guys, I'm picking up a few things as my local indoor track is opening soon. I was wondering if the Exotek spring perches were worth it? Mine would pop loose on occasion. Thanks!
TEKNO EB48.3 / ET48
AE T5M / B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 08-23-2015, 02:26 PM   #9763
RENOV8R's Avatar
Check that the slot in the stock perches are facing to the rear every time you drive it, and they shouldn't pop off very often. I've got the Exoteks, but they're more of a bling item IMO
Old 08-23-2015, 03:41 PM   #9764
nitro2be's Avatar
Just shy for me
Old 08-23-2015, 03:44 PM   #9765
nitro2be's Avatar
He's correct. And if you do get the bling you can use a small zip tie to ensure you don't loose one. Or u can even drill a hole in the stock ones.Through the hole and around spring
