Hot Bodies D413 1/10 4WD Buggy
#9901
Yeah, it dawned on me after I posted that you could limit droop with internal spacers. Funny, I 've never played around with droop much. On my ebuggy, I just tighten the screw until the shock end is aligned with the standoff then give it another 1/2 turn. That way I know I have full droop but am not putting any strain on the shock ends or pistons.
So back on topic as it relates to the D413, can anyone explain layperson terms what the benifit of running less droop in the rear is or what kind of change I can expect?
#9902
The more droop you have , the more weight is allowed to transfer .
The less droop you have , less weight is allowed to transfer.
A car with more droop tends to jump or land better . It will Also handle bumps better and because of the weight transfer fore and aft it should be better on low traction tracks.
A car with less droop responds more quickly , is more stable , and is better suited to higher grip and smoother surfaces.
My track starts a dusty mess and everyone is running lots of droop. When the mains come around and the brown line of grippiness has formed , people are taking droop out .
It is a significant part of the tuning equation.
#9903
#9904
Has anyone tried the Factory RC C/F rear camber link plate? Just wondering how it stands up to abuse
#9906
#9909
Same here all good
#9910
I have a question .... I am going 5.5t and I am wondering if thinner center diff fluid leads to higher temps at the motor ? I can see it in my mind doing that , but I am really not that smart . I have 50k in my center diff now , and I like the way the car drives.
Anyone test this ? It seems like the sort of thing someone has looked into
#9911
#9912
What wheels can I run with this car?
#9913
#9914
#9915
