Ok just for the record i didn't break my truck physically, just my esc went out for some weird reason and i got rid of my flysky for a futaba 4pl. (flysky caused me 2 runaways in one race). I decided to get another mamba max pro esc because i have always had good luck with castle stuff. (i know all the jokes about their stuff catching on fire). Figured the mmp is $107 and the hobbywing sct-pro is $87, why not get somethjng i can adjust better.(never could get my hobbywing to program from my computer). Already had the castle link software and programming card. Oh just cause i didn't use enough parenthesis, here (you go).
Really impressed with the futaba 4pl. Has a ton more features than i will ever use and is really comfortable. My servos were noticeably a lot faster after making the switch. At first i thought i had just gotten a bad $250 radio but after ruling that and everything else out, i knew it was the esc. Just kind of hard to go back to an esc that has only features i can use through my lcd card. Never could get the software to hook up right and work with the lcd programming card. I just know with castle stuff i can reach all those features that i need, even if it means occasionally bringing a laptop with me to the track. (got the field programmer so i really don't have to). Not to sure about hobbywing customer support,but i know for a fact castle customer support is awesome.
Mate if your fast with the truck you have, you will have a huge smile when you see how fast you can drive this truck.
I was looking at the alloy front bearing mount for your center diff, the one with two bearings, looks really nice, but it would cost me a lot by the time it's on my door step. Took a look at the stock plastic mount, milled out the hole that holds the bearing, pushed a second bearing all the way forward, replaced the stock one, done, center diff wobble gone. Should be strong enough, will post results.
Now working out the rear one, I have a plan
I had the same when I first drove mine, within three laps I held some gas while jumping, truck flies great, just learn how it needs to be driven.
R/C Tech Elite Member
What's wrong with a heavy front? I found this truck 1000 times easier to drive than the 2wd trucks. If you look at the pro drivers, their cars tend to nose dive a little.
A diff shouldn't leak without the diy stuff. So if the new part is related to the diffs it'll be leakless out of the factory I would imagine.
It all comes down to driving style. The SCTE definitely has more weight on the front axle than other trucks. Some guys like stock chassis with the battery forward (52/48 weight dist) some guys like the MIP chassis (45/55 weight dist).
With my tray in the rearmost position the truck has a 49/51 weight dist. It tends to make the truck a little easier to drive and jump flatter.
If you did so, what are your conclusions?
Here's hoping. Actually - here's hoping its a running change to the roller or a full kit is offered. I don feel like spending $100 for bits and pieces. My trucks starting to feel a little worn out - I'd like to just buy a new one or a kit with all the fancy bits.
Yes, that's how my prototype was set up. It doesn't make that much of a difference in the weight dist, but the motor wires are longer and run over the center diff.
Yeah I tried the same approach but went to stock form ont the ape. I wanted to shoe goo my esc behind the motor but did not think that the esc would like that much vibration.
Just got a set of Avid bearings for my truck. Does the rubber side of the bearing go in or out? Thanks.
You want the rubber to face the dirty side to keep the dirt out of the bearing. the metal side has less resistance so you get a little of "best of both worlds" with those bearings.
