Like Tree9Likes
Old 11-24-2011, 10:49 AM
  #24766
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Originally Posted by mtnbiker67
So besides De Racing rear skid plate, are there any other options out there?
It looks as though that's something that's needed on the truck.
I run this skid from T Bone Racing , since I put it on I havent broken a rear bumper and I am running the old design .
http://t-bone-racing.net/Short-Cours...AJ02-p498.html
BashemSmashem is offline
Old 11-24-2011, 11:10 AM
  #24767
the viper rc copperhead system that comes out in december is a good choice. the novak system is also a good option if your not wanting to spend alot of money http://www.amainhobbies.com/product_...e-45T-SC10-4x4
Originally Posted by RED-LINE M03
Ok thanks guys.....
Could you direct me to a good cheapo brushless system that would work good for this SCT and work in the open class.
cm.stites is offline
Old 11-24-2011, 11:55 AM
  #24768
dtr
dtr's Avatar
Ok thanks guys.....
I have had good luck so far with castle sidewinder sct combo, with a fan on the esc it never got more than 30 above ambient. I use it with an analogue Airtronics 94358Z servo, it seems that with a digital servo you need an external BEC, but that's just a few bucks and some soldering.
dtr is offline
Old 11-24-2011, 12:31 PM
  #24769
Happy Thanksgiving everyone!
hacker07 is offline
Old 11-24-2011, 12:35 PM
  #24770
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
you too, and thanks for everything you do for us SCTE guys in this thread.
RC*PHREAK is offline
Old 11-24-2011, 12:48 PM
  #24771
Trader Rating: 23 (100%+)
Originally Posted by picco007
Hey guys, I have a question. I just recently changed out my diff grease to diff lube in all 3 diffs. I went 3-3-1, Is that a good start? The car didn't feel planted at all, it felt unpredictable and I could not drive it agressively at all. With the stock diff's i could drive it aggressive or not and it worked great. I know this has been asked before but does anyone really know what diff grease are in the diffs from LOSI? Thanks for any of your help. Also, how much toe out do you normally run?
Dustin evans latest setup uses 3/3/2 in the diffs. I just changed mine to this from 5/5/3 and the springs he uses also i believe blue front purple rear......not sure how the truck will feel now but will see tomorrow nite. Runnin on hard packed indoors
nitro0619 is offline
Old 11-24-2011, 12:59 PM
  #24772
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Sold.....
Bondonutz is offline
Old 11-24-2011, 01:01 PM
  #24773
Grandturk's Avatar
Originally Posted by Bondonutz
NIP complete Gear diff assembly and stuff for sale
http://www.rctech.net/forum/r-c-item...plate-nip.html
That would be sweet if I had a SC10
Grandturk is offline
Old 11-24-2011, 02:09 PM
  #24774
willbe's Avatar
Originally Posted by rcgod
Are you using solid bullet connectors? I was using a deans plug with solid bullets and had the same issue. Took the deans out, got some good quality solder and a good iron and end of issues. This truck is heavy and puts a lot of load on electronics. A cold solder connection will cause problems. If your solder joint is dull and not smooth it is probably suspect. It should be shiny.
Coal train knows how to solder and owns a LRP equivilant digital soldering station.
Could the sensor wire possibly of gone bad?
willbe is offline
Old 11-24-2011, 03:24 PM
  #24775
rcgod's Avatar
Trader Rating: 33 (100%+)
He came in here looking for advice and I gave it to him. But thanks for the update on his soldering skills. I'll make sure and file that away. Lol.
rcgod is offline
Old 11-24-2011, 03:43 PM
  #24776
DBARB's Avatar
Let me know how the diff oil works out for you. Thanks
DBARB is offline
Old 11-24-2011, 04:19 PM
  #24777
willbe's Avatar
Sorry rcgod, Didn't mean any offense, just trying to help check one other thing off as people read thru the thread.
I know that he and the kids are at his folks for the holidays.
As he said, nothing changed other than moving everything from vehicle to the scte.
willbe is offline
Old 11-24-2011, 04:21 PM
  #24778
I have been running this setup on a medium size, medium traction track. It works great as long as you have throttle control. Rotates very good and does exactly what you tell the truck to do.
losi b is offline
Old 11-24-2011, 06:06 PM
  #24779
So I finally broke down and got myself a SCTE. I plan on using my MMP I have sitting around in conjunction with my castle 3800kv 1410 motor (with the 3mm shaft). Two questions:
1. For those of you using the 3800 on this truck, what BRAND of pinion gears are you using? It seems like it needs a shorter pinion and the one I have wont work. The stock 3800 shaft doesnt stick out too bad so i really need a short pinion.
2. on 2s lipo, I plan on running this Hog at WCRC, OCRC, and SDRC.... all of which are small-medium sized indoor clay. Im thining a 14t pinion to get a baseline? Please advise.
Thanks!
Fleshgearf150 is offline
Old 11-24-2011, 06:09 PM
  #24780
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Thanks!
1. I use Robinson Racing Pinons, they are hardened, Very little wear.
2. Never raced at any of those tracks Sadly, no input there sorry.
Feint Motion is offline
