Like Tree9Likes
Old 08-12-2012, 09:04 AM
  #38266
Hello,
There is no LOS-code for the longest srews that holds the rear differential and bumber together. How can I order them?
mamyllyn is offline
Old 08-12-2012, 10:39 AM
  #38267
These should be it. http://www.losi.com/Products/Feature...rodId=LOSA6198
tonyxcom is offline
Old 08-12-2012, 11:29 AM
  #38268
Originally Posted by .AJ.
What chassis braces should I run with KHZ chassis???
I'm thinking the same thing as i just noticed that my KHZ chassis is slightly bent just in the front of where the stock plastic brace is mounted to the chassis. It's nothing big but enough to be seen when watching from the right angle.
Anyway, wondering if some other brace than the stock one is supposed to be used with this chassis.
Lomb4rd is offline
Old 08-12-2012, 12:26 PM
  #38269
nanoverse's Avatar
Hi,
Which are the newer diff gears the lower or higher ones? Also can you mix and match these?
nanoverse is offline
Old 08-12-2012, 12:29 PM
  #38270
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by nanoverse
Hi,
Briguy is offline
Old 08-12-2012, 01:31 PM
  #38271
http://www.kingheads.com/product_inf...7fea5f578e301d , This is the one I run, it docent flex as much but I don't think you'll bend your chassis.
jnyrcr is offline
Old 08-12-2012, 02:33 PM
  #38272
nanoverse's Avatar
Originally Posted by Briguy
http://www.rctech.net/forum/10201613-post28020.html
Umm, thenewer ones are the higher ones without the flat part?
Old 08-12-2012, 02:43 PM
  #38273
Originally Posted by chucko
I read you post and wanted to bitch slap U. try asking in a nice manner. you might get 4 posts with fans on ebay. amain tower. if you want. Tekin has a site with numbers and prices. buy two for 19.00 or 22 depends on where you search. Part numbers. there's to many
I'm sorry for asking a direct question, please forgive, don't hit me, I'll never do it again. Don't worry I'll learn to ask questions so as not to make you so mad at me. I try my hardest to learn my place.
Are kidding me? Listen up bitch slapped, I'm not your wife who seems to be financing your hobby. I searched the sites and didn't get a definitive answer, so I posted a simple question to the point. Kiss my axi.
Jeffem62 is offline
Old 08-12-2012, 02:52 PM
  #38274
Briguy's Avatar
Originally Posted by Jeffem62
Fan or heat sink for the Tekin Pro 4? Links if you have them?
Both of you guys could learn to act a little better .
Anyways , to answer the question . There is no specific fan for Pro 4 motors . There are many different fans made my many different companies that will fit . Any fan made for a 540 motor will work .
Briguy is offline
Old 08-12-2012, 03:00 PM
  #38275
dtr
dtr's Avatar
Yes. Those have wider teeth so load is distributed more.
dtr is offline
Old 08-12-2012, 04:42 PM
  #38276
Raced my new SCTE for the first time today and was amazed, it handles really well (a little slower turning and a heavier feel then my DESC410R) but holy crap is it tough! So much bashing/crashing in my class and it just kept going, I really like the SNR chassis and just ordered some RPM Skid Plates (front and rear) to help protect it.
Anyone running a protector on their SNR chassis? If so where can I get one?
Jim Bob is offline
Old 08-12-2012, 06:03 PM
  #38277
dethklok151's Avatar
Trader Rating: 65 (100%+)
Another post about motors and batteries. I was a little surprised to see that my setup and my buddies setup had such common results. We both run basically stock weight trucks.we both ran same new 6000mah packs. I run the bl120a esc with a castle 1410 3800kv motor.he runs the mmp esc with a $30 chinese two pole 3660 3500kv motor - basically a bigger velineon motor. When I recharged both batteries the day after the race,I put 4000mah back in mine and 4300mah back the pack he ran. In our 8 minute main,I had second for all but two laps. The guy in first works at a hobby shop and after I choked, the track owners son passed me for second with two laps to go. I lapped my buddy a few times though. I know driving style had something to do with it but I was still surprised that both setups used about 500mah/minute. Both motors temped around 160 .
dethklok151 is offline
Old 08-12-2012, 07:03 PM
  #38278
Razorbelly's Avatar
______________________________________
If ur running the 4600 pro4, u will likely need one. The castle
Creations will fit perfect and r 11 bucks. CSE011-0014-00 36mm
The 4000 pro4 will likely run cooler. If u r still having heat issues
Try 3,3,2 in ur diffs.
Razorbelly is offline
Old 08-12-2012, 07:04 PM
  #38279
Razorbelly's Avatar
If ur running the 4600 pro4, u will likely need one. The castle Creations will fit perfect and r 11 bucks. CSE011-0014-00 36mm
The 4000 pro4 will likely run cooler. If u r still having heat issues ,Try 3,3,2 in ur diffs.
Old 08-12-2012, 07:16 PM
  #38280
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Why is that in your signature? Or why did you try and make it look like your signature?
Rockthecatbox21 is offline
