Like Tree9Likes
Old 10-03-2012, 07:59 PM
  #39796
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by nitro_mt_racer
When you put the inserts in, are they flush with the outside of the diff case or are they extended a little bit? They should be extended a little.
They had an incrementL amount sticking out. I made sure to push them in as far as they would go. Really getting sick of these diffs and wish an aftermarket company would make improved ones.
Rockthecatbox21 is offline
Old 10-03-2012, 08:09 PM
  #39797
scracer68's Avatar
Try using RTV next time on the inserts. Mine always turn out smooth.
scracer68 is offline
Old 10-03-2012, 08:22 PM
  #39798
I just remembered some people tried using 2 paper diff seals instead of 1. I think that should free up the diff action a lot. I know there's a way to do it since other people have used ca no problems.
Old 10-03-2012, 08:33 PM
  #39799
nitro_mt_racer's Avatar
Trader Rating: 246 (100%+)
Yeah, it's not the type of adhesive/silicone that you used that caused the problem. Either the inserts aren't all the way down or something isn't seated correctly. A 2nd gasket will help your situation until whatever isn't seated correctly shifts and then you'll probably end up replacing the gear set. My brother-in-law went with the 2 gasket setup to help stop the leaking but then ended up stripping the gears once they got broke in because the mesh wasn't tight enough.
nitro_mt_racer is offline
Old 10-03-2012, 09:01 PM
  #39800
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
i sealed my xxx-sct gear diff with black gasket sealer in a little tube from the autopart store. it is like liquid rubber that firms up after a bit. i just put it on thin with a tooth pick. and it was awesome. no leaking at all ever. comes apart with a hobby knife blade no problem.
ryanpatrickgore is offline
Old 10-03-2012, 10:31 PM
  #39801
Suteki's Avatar
Well got kind of sick of my losi tonight. Tried sealing the diff inserts with ca glue and made sure to not get any excess where it wasn't supposed to go. Let it dry and began to put the spider gears etc back in like i always have. Everything meshed up right and felt smooth until i started tightening the diff screws. Seems the diff started locking up really badly around 1/2 a turn to snugly tight. The gears were meshed, but seemed too tight and the diff action wasn't smooth. Even did what ya'll said to break it in using a power drill on the outdrives. Felt exactly the same as before and the diff was getting warm from all the friction. I can usually put my diffs back together great and i have done it at least 15 other times before, but this one just doesn't feel right.
Mine would do the same, especially the center, when you started firming up the screws it would bind and become very notchy. I backed the screws off until it was smooth and used some red RTV silicon gasket sealer around the crown gear (or spur gear in the case of the center diff). No leaky diffs, smooth action.
Suteki is offline
Old 10-03-2012, 10:42 PM
  #39802
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Originally Posted by RC*PHREAK
not a good idea. i've destroyed a few esc cases using electric parts cleaner to remove servo tape. it causes the plastic to get very brittle.
Hmm I will see. I have a milled chassis thats why dont like servo tape not enough to latch onto but its movable at least. Maybe Ill fashion a cf tray which bolts onto the sideguard screws behind the motor.
aloksatoor is offline
Old 10-03-2012, 11:47 PM
  #39803
nanoverse's Avatar
Might be a bad case. It's best to push the inserts in hard and the glue them inside and outside with that waterlike CA. Yeah, the bottom insert should stick out about a fingernail height and the top a little bit less.
Also we at our club let the papergasket soak in brakecleaner and put RTV gasket sealant generously on it.
If the diff feels notchy it's best to start over or change the case.
nanoverse is offline
Old 10-04-2012, 12:12 AM
  #39804
Trader Rating: 90 (100%+)
Double the paper gaskets and you can tighten it more without leaks. Maybe it's time to buy a new $5 diff case?
Kuya_Kimo is offline
Old 10-04-2012, 12:33 AM
  #39805
Suteki's Avatar
I tried a different diff case with mine and had the same problem. So buying another isn't necessarily going to solve anything.
Suteki is offline
Old 10-04-2012, 05:32 AM
  #39806
Well i've ran all three diff cases the entire season, so i fon't understand why the ca would cause all these problems. I'm just worried if i put two seals on it, once the diff breaks in, i'll end up having loose gears and stripping them.
Old 10-04-2012, 05:48 AM
  #39807
Grandturk's Avatar
Leave out a shim.
Grandturk is offline
Old 10-04-2012, 06:02 AM
  #39808
Devigili22's Avatar
Trader Rating: 29 (97%+)
You may be overfilling the diffs.
Devigili22 is offline
Old 10-04-2012, 08:26 AM
  #39809
allan42r's Avatar
i had the same problem, the inserts were not in the case all the way. it doesnt take much but id bet a pepsi lite thats your issue.
allan42r is offline
Old 10-04-2012, 08:47 AM
  #39810
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
or the spider gears/pins aren't seated all the way down (with the stock square blocks sometimes you have to put a lot of force on them to get them fully seated which is the main reason why i like APE's round bushings).
RC*PHREAK is offline
