Team ORCA USA Discussion Thread
#1126
Regional Moderator
Found it. Thanks.
#1128
So far I've had success loading the programer card ver 4.4. But cannot get the ESC ORCA BP1001 Firmware VER 2.1 to load.
I've reformatted the mini SD card (FAT32) and loaded the card, but cannot get the ESC programer card to work--It shows programcard ver 4.4 okay but nada anything else.
What am I doing wrong??????????? Can't get the ESC updated.
Do I need to reformat to NTFS or exFAT????????????
#1130
WOW!! I don't know wht happened or what I did....................... but I got ver2.1 to load.
At last.
Probably won't ever touch the damn thing again
Thanks for all the help. You guys are the greatest
At last.
#1131
#1133
I believe you must use an sd card. Make a folder called firmware in the sd card and put the file in there. Then put the sd card in the box and update it.
#1134
I pick up sport binky ... Runing tc 21.5 do I need to run a fan and the cap?
#1135
The cap should always be used, regardless of motor power. Fan is not always necessary, but I run one on almost every ESC in my cars.
#1137
Hello together,
I recently purchased an brand new ORCA OE101. Problem is now, that the ESC is not doing the calibration process with the transmitter. It accepted throttle and break as it was. Further I can not programm it with the setup card. I have this ESC two times, and also an OE1 and the first two ones worked perfectly and now the third one has this problems. I also tried with a different transmitter and receiver, but the same result occurs. Does anyone experienced something similar? In the manual there is no point stated where you can force the ESC, to do the binding process...
Thanks in advance.
Thanks in advance.
#1138
Hello together,
Thanks in advance.
Thanks in advance.
#1139
Hi,
I got the calibration now with the transmitter. It was definitely my own stupid mistake. But the setup card is still doing nothing. So this two problems seem not to correlate to each other. I will try to update the software. Honestly I have also no other ideas anymore. Thank you for the tip.
#1140
Hi,
