Team ORCA USA Discussion Thread
#1113
You need to update the program card first if you want to program your ESC with the program card. Upload the latest firmware onto an SD card and insert it to the program card. Use a USB cable to provide power to the program card and update it. You should be able to link to the Blinky Pro ESC after that.
#1114
#1115
Make sure the files are all in the folders with the correct names. Sounds like it’s looking for something not there, the box only knows to look in a folder with a certain name
#1117
#1120
I recently bought an ORCO bl
+inky Pro ESC and a program card. BUT no way to link the ESC to the program card. I am missing the 4 wire cable and don't have the correct connector to make one. Who do I go to for get the missing wire?
#1122
If you have an extra sensor cable, you can cut it so it is 4 pins wide and that will work
#1123
Yeah, that's what I ended up doing. It had the correct pin spacing & ended up working just fine.
#1124
#1125
