Team ORCA USA Discussion Thread
#1171
Regional Moderator
Hello I recently picked up an r32 esc. I realize a bit older. What I didn’t realize is I need a program card. Not many of those found anymore. Are there any options? Will the OE1 card work?
I may just be put out and sometimes that happens.
Any help would be much appreciated.
#1176
I have a Totem 1S that has stated acting up recently. About a month ago the sensor wire went bad and when I would tap a board the unit would shut down and flash purple. Took a little messing around, but figured out it was the sensor wire. Replaced that and it ran fine until Saturday 4/13/24. I was getting ready to go out for my last run of the day when the car lost throttle, picked the car car up and everything looked normal. Turn the car off and back on and I had throttle again. Set the car down ran a lap(at part throttle) and it ran fine. As soon as I pulled full throttle it would die again, it's almost like it goes into voltage cut off. Shut the car off and back on, it works again. Holding it in the air it works fine, but as soon as load it, it cuts off at full throttle. I've tried a different motor and it does the same thing. Put a program box on it and the box lights up, but nothing comes up on the screen. Hooked the box to another esc just to double check the box and it worked as it should. Anyone have any ideas what this could be? I just got this esc back in January. Thanks for any info offered.
#1177
Regional Moderator
