Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 11-27-2007, 10:01 AM
  #991
Joe Ford's Avatar
Originally Posted by barber
it would not last long at those temps.
I've got hundreds of runs on my TC3 and Menace GTRe with 4s 4600 and 2/3s 5700 setups in them respectively...same ESC with both vehicles. ESC gets so hot it'll melt skin every run...keeps going and going and going.
Joe Ford is offline
Old 11-27-2007, 10:30 AM
  #992
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
Joe,
Does Castle have plans to make a more race oriented ESC in the future for 1/10 scale applications? I loved using my Mamba Max in my 1/10 scale vehicles, but it was alittle on the big side of things.
Also, is the only thing pretty much not legal about the Mamba Max systems the motors that come with them? Any plans to make motors that would be legal and also allow you to solder direct to them?
Finally, any word on when the software update will be out for the Mamba Max that will work better with Neu motors?
Cain is offline
Old 11-28-2007, 07:21 AM
  #993
barber's Avatar
joe that means that i need not worrry about my temps then ( gear to win)
barber is offline
Old 11-28-2007, 08:50 AM
  #994
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I just wouldn't get carried away. Try to keep the temps somewhat resoanble as even though it is capable of running at higher temps than pretty much any other speedo I wouldn't run it at those temps every time. I think if it happens every now and then you just don't have to worry like you do with other speedo's.
wyd is offline
Old 11-28-2007, 03:26 PM
  #995
barber's Avatar
joe you have a pm
barber is offline
Old 11-28-2007, 03:35 PM
  #996
wyd
Tech Legend
wyd's Avatar
joe you have a pm
I think he is away for the Mini Nationals and won't be back til Monday sometime.
wyd is offline
Old 11-28-2007, 04:28 PM
  #997
barber's Avatar
thanks
barber is offline
Old 11-30-2007, 07:11 AM
  #998
badassrevo's Avatar
Originally Posted by latemodel13
Hi I'm running a mamba max 7700 In a dirt oval car and when i gear it hard the speed control gets hot from no air getting to it. I checked it after a run and it was 290 degrees! Can someone give me an idea where to buy a cooling fan to put on it? I have seen them before but can't find one now. Thanks
here is a pic of a 25mm novak fan mounted directly to the heat sink. You can use 4/40 srews to thread inbetween the fins on the heat sink.
badassrevo is offline
Old 12-01-2007, 01:33 PM
  #999
matt d's Avatar
any setup to run the novak 13.5 without all the cogging. man is it bad unless you keep moving foward then its ok. once you stop or hit a board it will go backwards for a half of a turn then stutter foward for a trun then be ok
matt d is offline
Old 12-01-2007, 04:02 PM
  #1000
Tech Legend
Cain's Avatar
Post your current ESC configuration. Also, the batteries you are using, are you still using the bullet style connectors, etc.
Cain is offline
Old 12-01-2007, 08:17 PM
  #1001
wyd
Tech Legend
wyd's Avatar
FOr now not alot you can do. The Orion 13.5 will hesitate alot less than the Novak. For now thats the way it is but it will get better soon.
wyd is offline
Old 12-01-2007, 08:45 PM
  #1002
Looks to me that you have done the 'hole mod' on your case. i too am having a few heating issues with my MM & im about to do this mod, but did you notice a significant decrease in heat?
Drift Demon is offline
Old 12-02-2007, 10:09 PM
  #1003
matt d's Avatar
Cain - right now its just the box stock setup. i havent had time to mess with it. ive been racin for 15 years and this brushless stuff is all new to me.
Wyd - i cant run the orion 13.5. the ustcc ( novak race) is novak motors only in rubber classes. and my guys at checkpoint would be alittle mad i think if i didnt run there motor. otherwise i would do it in a second.
Thanks for the hel guys ill just have to start messing with it. i will post if i can get it figured out.
matt d is offline
Old 12-05-2007, 08:25 PM
  #1004
wyd
Tech Legend
wyd's Avatar
Well good thing is the Checkpoint brushed motors run well with the Mamba so your still good for 19t and stock or mod with no problems. I ran mine bushed for months before I ever put a brushless motor in my cars.
wyd is offline
Old 12-06-2007, 07:12 PM
  #1005
wyd
Tech Legend
wyd's Avatar
Joe here is the newest paint job. Paint is still wet so I didn't even cut it to fit the new offroad car yet. Pics just don't do it justice.
wyd is offline
