Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#1981
Tech Legend
Trader Rating: 51 (100%+)
Thanks Joe.
#1982
I've had issues with heat in my 5700 MM with the xxx-t cr. I've put in 15/82 and still hitting 200+. Someone has suggested going the other way with the pininon, with the theory that with a larger pinion the motor will turn less RPM at the same speed. Everything around here and manuals suggests lower tooth pinion.
I'm running 8000 Maxamps 2s lipo. After 10 minutes, I'm at 160. Guaranteed 200 at 20 minutes. Running on packed clay track, and also another track with loamy dirt conditions. Seems to run hotter on the loamy dirt.
CC says the heatsink will only reduce temps 10. He also said make sure there is no binding in my drivetrain/tranny.
I'm out of patience. Next time it hits 200, I'm shipping it back.
#1983
I'll speak with Bernie and see what we can do. Please email me your shipping info, full name, etc. [email protected] and put "SW1/10" as the title so I'll be able to spot it fast for you.
BTW...anyone interested in pics of RCX '09 look here. http://www.rccars.com/forums/showthread.php?t=3239
#1984
Tech Legend
#1985
Hello. I have a problem with Mamba max 7700 combo. With 2 my friends we buyed 3 combos before 1.5 years, but even from then my mamba wasnt nothing special. My other 2 friends are very satisfied and said ther combos are just perfect, got lots of power and woundering how mine cant even spin the tires on full throtle. Their monsters just go crazy and everything seems to be perfect for them, but not for me. We use the same batteries. So I run on 2 cell 8000mah with almost all setings on low. Punch on 50%. I have the 1.17 version on the ESC. Temps goes very high(more then 200F) thatswhy I keep all on low. I run HPI super electro. Normally its with 81/36 spur/pinion. I run my mamba with 93/24. Its the lightes possible gear ratio I can use and still I dont have the needed acceleration and the ESC goed over 200F. Motor is around 170F.
My question is this:
What can be wrong with my mamba? Is there something in the ESC that can be factory damaged or not properly working that can make this low power symphtoms? My friends are woundering how could mine mamba be so slow?
Everything works fine, I havent got any problem with operation, or anything else, just this low power all the time. When I hit the throttle my car accelerate slowly like a fast toy. I've calibrated the mamba several times, checked the radio, everything is good. Is my combo still in guarantie and eventually how can I send it from Bulgaria for checking whats wrong with it?
Is there anything I can do to find the problem? Its just not fast like the mamba max 7700 combos, that my friends run and as it should mamba max must be
I really hope to give me any idea what should I do.
Thank You,
S.Ganchev
Thank You,
S.Ganchev
#1987
With a MMM V3 the for the first power up the fan came on and cycled briefly- now programed, with the latest firmware and calibrated with the radio, it does not come on at all. 150 deg is not reached, but initially when powered up it would cycle to say "im ok" until binded with tx. Anyone else having this problem? ESC is brand new.
#1988
Can the Mamba Max esc be programed to make a loud beep when the Lipo Battery voltage drops to 3 volts per cell?
if so how can this be Done?
#1990
i was useing the castle creations pheonix 25 and when it was programed to shut of ar 3 volts per cell it would make a real loud BOING when it reached the cut off leval.
#1991
Joe Ford, you have a PM. I got my MMM replacement and have a question...
#1992
Joe...got your PM an responded. Thanks
#1994
Thought you guys would enjoy this. First run of my high speed car I'm writing a conversion article for (don't ask for more info, it'll be in the article). Just had to share this with you guys. Geared for 140mph...have a "little" tweaking to the car before I'm going to get there....
http://www.youtube.com/watch?v=NxP0MjOxPyM
