Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 07-07-2016, 08:57 AM
  #14896
One last quick question.
Do you guys know if they make a steel or aluminum diff housings?
Vyevchevski is offline
Old 07-07-2016, 09:46 AM
  #14897
NutDriver's Avatar
Trader Rating: 30 (100%+)
Not that I know of.
NutDriver is offline
Old 07-07-2016, 10:10 AM
  #14898
oreo's Avatar
Default .....diff housings.....
Greetings Vyevchevski; Aluminum transmission cases -RDLogics seems to still have them in stock.Part #81381; I think this is what you mean by "diff housings"..-Greg
oreo is offline
Old 07-07-2016, 12:28 PM
  #14899
Awesome!! I will have to buy a couple to replace the plastic ones. May get more aluminum parts for it too, if I can find them.
Old 07-07-2016, 03:40 PM
  #14900
gigaplex's Avatar
Aluminium is heavier than the plastic parts. I wouldn't recommend switching to aluminium everywhere for the sake of it.
gigaplex is offline
Old 07-08-2016, 03:14 AM
  #14901
I am looking to buy a reliable and cheap touring car to start on my club track.
I own an AE B5M and a Losi XXX SCT.
I was initially thinking of a Sakura XI Sport but not sure it will be enough reliable and I do not want to spend time replacing part. I know AE products are usually good.
XRay TC14 is out of budget.
TT-02 is less attractive than AE TC4.
How reliable is a TC4 Club Racer out of the box?
Is TC4 Club Racer closed to End Of Live ? Or will it continue to be produced?
What are the parts to change to make reliable? Front CVD ? What else?
Thanks.
julieng is offline
Old 07-08-2016, 08:24 AM
  #14902
I was thinking maybe only the CVDs and Differential Housings.
Old 07-08-2016, 08:49 AM
  #14903
1spunspur's Avatar
CVD's and diff housings are fine. No need to change. Some people complain about CVD's binding during hard cornering but I have not noticed that with mine.
1spunspur is offline
Old 07-08-2016, 04:06 PM
  #14904
gigaplex's Avatar
You may want stronger CVDs and diff outdrives if you've got a powerful motor, but there's no need to change the diff housings (the gearbox itself).
gigaplex is offline
Old 07-08-2016, 05:39 PM
  #14905
tmail55's Avatar
Trader Rating: 61 (100%+)
julieng
A TC4 makes for a good VTA RC.
tmail55 is offline
Old 07-09-2016, 10:01 AM
  #14906
32819toon's Avatar
Just bought the RTR to run outside on low grip asphalt. What upgrades do I need for it and what oils should I use in the shocks ? Are the tyres any good ? We all use Rallyblocks as the grip is so low.
32819toon is offline
Old 07-10-2016, 12:36 AM
  #14907
DesertRat's Avatar
You really don't need much in the way of upgrades for what you describe, the chassis is a solid piece that will get you running and respond predictably to tuning changes. If you feel like spending some money on the car the most useful 'upgrades' early on are tuning pieces like springs, swaybars, a faster servo, that sort of thing.
Shock oil in touring car is typically between 30 and 50 weight, with 35-40 being most common in that range. Losi or TLR shock oil is pretty good and as its silicone (all shock oil is these days) it wont degrade with time. I prefer it to Associated oil because its dyed and you can see what kind of oil you had in the shock before, in case I forgot. I forget things like that.
The kit tires are a long-wearing hard rubber and are perfectly good for running around in the street but will be much less grippy than the softer Rally Blocks.
DesertRat is offline
Old 07-10-2016, 01:55 AM
  #14908
32819toon's Avatar
Thanks DesertRat. I've been racing touring cars for about 10 years, but only raced Minis outside.
I'll be putting a faster servo in and a brushless 13.5t system. I'll use the kit electronics in one of my Minis.
Old 07-10-2016, 06:55 PM
  #14909
Default Hi
Just got my dc4 apex done
Zgmfx01atc4 is offline
Old 07-10-2016, 07:03 PM
  #14910
Default Set up
Team associated apex and tc4 club convert to dc4 yes dc4 with gear diffs with mmp2400kv 47p 66 spur on 4s 126mph radar gun lol takes 10 runs not even hot only 40c (motor temp)
