Team Associated TC4
I am looking to buy a reliable and cheap touring car to start on my club track.
I own an AE B5M and a Losi XXX SCT.
I was initially thinking of a Sakura XI Sport but not sure it will be enough reliable and I do not want to spend time replacing part. I know AE products are usually good.
XRay TC14 is out of budget.
TT-02 is less attractive than AE TC4.
How reliable is a TC4 Club Racer out of the box?
Is TC4 Club Racer closed to End Of Live ? Or will it continue to be produced?
What are the parts to change to make reliable? Front CVD ? What else?
Thanks.
Thanks.
Just bought the RTR to run outside on low grip asphalt. What upgrades do I need for it and what oils should I use in the shocks ? Are the tyres any good ? We all use Rallyblocks as the grip is so low.
Shock oil in touring car is typically between 30 and 50 weight, with 35-40 being most common in that range. Losi or TLR shock oil is pretty good and as its silicone (all shock oil is these days) it wont degrade with time. I prefer it to Associated oil because its dyed and you can see what kind of oil you had in the shock before, in case I forgot. I forget things like that.
The kit tires are a long-wearing hard rubber and are perfectly good for running around in the street but will be much less grippy than the softer Rally Blocks.
Thanks DesertRat. I've been racing touring cars for about 10 years, but only raced Minis outside.
I'll be putting a faster servo in and a brushless 13.5t system. I'll use the kit electronics in one of my Minis.
326Likes
.-Greg
