Like Tree238Likes
Team Associated TC4
Old 07-11-2016, 07:05 AM
  #14911
1spunspur's Avatar
Originally Posted by Zgmfx01atc4 View Post
Team associated apex and tc4 club convert to dc4 yes dc4 with gear diffs with mmp2400kv 47p 66 spur on 4s 126mph radar gun lol takes 10 runs not even hot only 40c (motor temp)
I'm not familiar with the mmp2400. Is that a Castle motor?
1spunspur is offline
Old 07-11-2016, 09:10 PM
  #14912
Originally Posted by gigaplex View Post
You may want stronger CVDs and diff outdrives if you've got a powerful motor, but there's no need to change the diff housings (the gearbox itself).
I run a 3300kv motor which puts out a lot of torque. So installing alum cvds may be a good idea?
Vyevchevski is offline
Old 07-11-2016, 10:00 PM
  #14913
gigaplex's Avatar
I don't know the specifics of that motor, but that kv rating is still in the ballpark of stock (13.5T) motors. You can probably get away with the stock parts, but you can always upgrade to aluminium parts later if you do break the stock ones.
gigaplex is offline
Old 07-11-2016, 11:56 PM
  #14914
Yes castle 2400
Zgmfx01atc4 is offline
Old 07-13-2016, 12:39 PM
  #14915
That was initially my plan, because parts do eventually break.
Old 07-17-2016, 07:21 AM
  #14916
32819toon's Avatar
Everything on the car is in imperial measurements. What size tools, eg hex drivers & allen drivers do I need ? What size are the wheel nuts on the car ?
32819toon is offline
Old 07-18-2016, 12:16 PM
  #14917
RotorTruck's Avatar
I bought these and use all of them on the TC4:
https://www.amainhobbies.com/mip-tho...FcRgfgodJtUGdQ
Wheel nuts are 11/32", a 3/16" comes in handy too.
I use this one when adjusting droop, easier to get down in there at an angle. https://www.teamassociated.com/parts...r_gold_handle/
Socket head motor screws are easier to work with too: https://www.amainhobbies.com/protek-...h-1202/p141675
RotorTruck is offline
Old 07-19-2016, 03:52 AM
  #14918
32819toon's Avatar
Thanks RotorTruck
Old 08-03-2016, 12:32 PM
  #14919
DesertRat's Avatar
Does anybody else have what looks like excessive play in their diff pinion shaft bearings? Did you put some shims in or just swap bearings more often than I have been?
DesertRat is offline
Old 08-08-2016, 11:18 AM
  #14920
RotorTruck's Avatar
Anyone have a setup for USGT?
Old 08-10-2016, 01:16 PM
  #14921
DesertRat's Avatar
For USGT tires I would start with one step harder spring in the front than the rear such as green rear and silver front, black or silver sway-bars depending on grip, middle roll center front and rear with long links, and full sauce both front and rear.
Just remember to look out for the chassis dragging.
Old 08-13-2016, 12:45 PM
  #14922
1spunspur's Avatar
I was just bashing with a friend , he has a 1/8 Traxas , I think it's a Slash.He has more battery (3s) and more motor. I was pretty respectful competition.We had fun.
http://www.rctech.net/forum/attachme...1&d=1471117501
Old 08-16-2016, 06:24 AM
  #14923
I got a TC-4 Roller for sale.... Used 4 times indoor carpet race's No Hard Crashes PM me if interested
Stock chassis
Upgraded to threaded shock collars
Futaba All Steel gears Steering Servo
4 Pairs of Rear A-Arms
4 Pairs of Front A-Arms
2 Spur gears no sure of teeth
2 Brand new Foam Tires Soft never opened in pack yet
I can send pics via cell phone as well
I upgraded to a different Class this year to Mud Boss
Viper10er7 is offline
Old 08-18-2016, 01:22 AM
  #14924
32819toon's Avatar
Had 1st race outdoors with new rtr tc4. Car went well on very low grip asphalt. Used stock set up apart from changing oils to 40wt up front and 25wt in rear, and used stock electrics and was quick. Had understeer entering corners, and oversteer coming out, probably due to grip levels. I moved the front shocks in 2 holes but I do still need more corner entry though, hopefully without making car more taily coming out of corners. Would changing to green rear springs help oversteer ? What about the understeer problem ? Like I said, I don't want to cure the understeer but make the rear of the car come out more.
Old 08-18-2016, 07:26 AM
  #14925
If you have droop screw adjustments, increase both front and rear droop: more rear droop should help with the push going into the turn and more front droop should help with the looseness on accelerating out of turn.
John Wallace2 is offline
