Team Associated TC4
There are only two versions; the TC4 tub version and the Factory Team TC4 graphite chassis. The TC4 Club Racer is the same as the original TC4 but now comes factory built with front spool instead of the original ball diff.
I think the original TC4 came with a front diff where as the club racer version now comes with a spool.
How come I don't see anyone using the outer two positions of the camber link mount? Since it increases negative camber gain as the suspension compresses,wouldn't that allow you to run less static camber at normal ride height? More camber gain would help on tight tracks? Plus with less static camber, theres theoretically a larger contact patch when accelerating, and less tire wear on the inner edge?
There was also a team kit that I believe came with the cabon(not carbon fiber)chassis parts and some of the aluminum upgrades.
front spool part number
Can anybody tell me the part # for the front spool that comes with the tc4 club racers?
Front Caster Blocks. I removed some 0 degree ones from the car, and have some new 4 degree ones here. I can't tell the difference by looking at them.
Can the Caster Blocks be installed on either side, or is one specifically for the left side, and other only for the right side?
Mark
Castor blocks
Figured it out, thanks guys. Here's a picture for reference. 4* Caster on left, 0* on right. I was expecting the top of it to be pushed rearward, but instead they just changed the angle of the lower pin hole. Cheaper easier solution.
I was surprised how worn the lower pin hole was on my club 0*. How often do these need to be replaced? I had to use a drop of Tri-Flow and needle nose pliers to push the pin into the new one. Old one slid in no prob by hand and has slop. Have 5 race weekends on asphalt plus about 12 packs of practice on a tennis court.
I raced my tc4 last night for the first time. I qualified 4th in the A-main and due to my inexperience I broke my steering rack in half. I ordered the aluminum rack and was thinking of running that with the bolt tightened down and a regular servo saver on the servo.
Another issue I had is the horrendous chattering in the front end. Since the jrxs cva's are non existent is there a solution? I run a front diff set tight. Should I run it loose?
Honestly, I would rather ream a bunch of front hubs to 10mm, so I can use 5x10mm bearings and any other brand DCJ drives.... The chatter is that annoying!!!
Mcmastercarr sells hand reamers in all sizes that can get the job done....
Now Associated should release a few 10mm hubs to help the situation, or come out with their own tc4 DCJ drives...
You shouldn't have excessive chatter with a diff unless you have it cranked way tight. your always going to have a little chatter with the stock cvds but if u back your steering endpoint off just a hair it will help. With slower motors(vta,usgt,and stock) I don't even notice the chatter. Highend mod power yeah its there but not excessively.(at least for me)
