Xray T1FK05
#4486
Originally Posted by CRASH
Basically you can use either Xray or PRS with no mods. Anything else and you will have to drill the third hole. Not difficult by any means but the PRS spur gears and pinions are the best out there in my opinion.
Later,
Later,
#4487
Yeah, I couldn't find any PRS spurs in stock anywhere. So I went with a Kimbrough 116 (biggest pinion for this is a 37 tooth). It fits. But remember this. The Kimbrough spur is off set. So if you put it on wrong, it'll rub. However, putting it on the right way.. the numbers on the spur (in this instance it's the 116) will slightly rub the motor mount. That's how close/clearance is. Just sand it down and it's all good. Now I just gotta find some PRS gears in stock.....
But yeah, wish they made a 4 screw spur mount. That would be nice.....
#4489
If you still want prs, try www.teammaximus.com
Heath has them in stock, plus plenty of xray stuff.
#4490
Team EAM
EA
#4491
Originally Posted by John Tag
Hey Jimmy what ya runing with a 37T...A slave 55T motor and 54 mm tires
Thanks for the update Eric. I checked out your site first when I was looking for them. But you were out and so was everyone else. I'll order 114 and 116 on Monday then...
#4492
MDawson: check your PM
#4493
#4494
Originally Posted by Joep
The new extra hard Xray spurs are now available. They are awesome.
#4495
I'm not sure if this is true or not, but does xray give you the updated thrust bearing for free if you call in and say you have an earlier fk05 kit? Anybody know the part number?
#4497
Nice ride! Where did you find that fan mount?
#4499
http://www.teamxray.com/teamxray/new...ce0e6a304d116d
#4500
Originally Posted by skinart76
They sent mine over for free of charge. Follow the steps on this link:
