Like Tree1Likes
Xray T1FK05
Old 11-04-2005, 03:18 PM
  #4471
Charles Godwin's Avatar
At this point i'm using white rears and light blues for the front on rubber tires but i think i need to go up another rate on the front
Charles
Charles Godwin is offline
Old 11-04-2005, 03:20 PM
  #4472
kerry's Avatar
what brushes are on your monster motor? is there any material taken off the brush(leading or trailing edges?) doing this will in a sense reduce the arching and have less material touching the comm. you should see a temp drop in the motor giving you atleast another tooth up. if your taking material off only take off .010. check out dc motor thread and also team brood. motor springs depends on brushes but i like to tune with purple + red - for F-brushes and 767's
kerry is offline
Old 11-04-2005, 03:33 PM
  #4473
Rob Mincey's Avatar
Purple/Red has worked for me on shorter tracks, Red/Red or Red/Green on larger, more flowing tracks has also worked. Have you checked to make sure that your arm is centered in the can and is not binding somewhere (over shimmed?) Also, make sure you don't have the gear mesh too tight or binding in the drivetrain.
Rob
Rob Mincey is offline
Old 11-04-2005, 03:39 PM
  #4474
kerry's Avatar
good points rob
kerry is offline
Old 11-05-2005, 01:58 AM
  #4475
Trader Rating: 27 (100%+)
Is there an aftermarket spur adaptor for the Fk05 that allows standard spurs to be used?
Thanks.
MDawson is offline
Old 11-05-2005, 04:50 AM
  #4476
Check out my New Products page. I have a new motor mount for the FK05 that allows for more forward movement of the motor which allows for larger spur gears. It also has a clearance cut in the side that aloows you to use other spur gears without the possibility of the spur gear rubbing. You can find these at http://www.teamtamale.com
teamtamale is offline
Old 11-05-2005, 06:09 AM
  #4477
Chrisgt2's Avatar
I just drill out my spurs......RW gears are excellent so thats what I do use them
Takes like 3 seconds
Chrisgt2 is offline
Old 11-05-2005, 07:30 AM
  #4478
CRASH's Avatar
Trader Rating: 26 (100%+)
Thanks.
Basically you can use either Xray or PRS with no mods. Anything else and you will have to drill the third hole. Not difficult by any means but the PRS spur gears and pinions are the best out there in my opinion.
Later,
CRASH is offline
Old 11-05-2005, 07:34 AM
  #4479
smyka's Avatar
i got one of the motor mounts and hand down the best thing i ever got for the car i can run a 120 TOOTH SPUR GEAR NOT AND GO AS HIGH AS A 37 PINION stock motor mount i could only run 120 /33
smyka is offline
Old 11-05-2005, 08:25 AM
  #4480
duckman996's Avatar
Trader Rating: 14 (100%+)
Originally Posted by HRCRACER123
Thanks Duckman. I made it flush and it is touching the cvd barely but I dont think it is touching it enouf to make a diffrence.
I would adjust the collar to move it away from the drive axle ... even a little bit of contact will cause friction - and if you bend an axle in a crash, there is going to be alot of contact which will cause some weird handling characteristics - the car will "snap" in turns because the front axles will bind.
duckman996 is offline
Old 11-05-2005, 08:45 AM
  #4481
team orange's Avatar
I just built my FK05 and noticed that in the rear, the tires are rubbing on the lower plastic shock cup. I'm using Parma tires. Whats the fix for this. Are BSR tires smaller or do I need to cut off a little bit of the tire on the inside of the rim of my Parma tires?
team orange is offline
Old 11-05-2005, 08:52 AM
  #4482
mike ivy's Avatar
Trader Rating: 51 (100%+)
Hey team orange,
just move in your shocks on the bottom a arm hole dont trim the rims hope this helps
mike ivy is offline
Old 11-05-2005, 08:58 AM
  #4483
Thanks mike.
Old 11-05-2005, 10:11 AM
  #4484
Scrad's Avatar
Trader Rating: 16 (100%+)
Nick, I can show you tonight where to cut the arm to use the outer hole.
Scrad is offline
Old 11-05-2005, 08:34 PM
  #4485
Later,
thanks!
MDawson is offline
