Like Tree1Likes
Xray T1FK05
Old 11-16-2005, 05:01 AM
  #4636
Glowster21's Avatar
Trader Rating: 136 (100%+)
Hey all...Picking up anf FK05 today and have some shock questions. I have heard of some using the AE spring perches. Will this work? also, I know the stock lower ball end hits the 28mm foam tires. Will the AE lower ball end with screw work in it's place? I have a ton of leftover AE parts as well as springs and would like to use them if possible. Any info would be great!
Glowster21 is offline
Old 11-16-2005, 06:06 AM
  #4637
Rob Mincey's Avatar
Originally Posted by wolfman76
OK, How hard is it to remove the rubber seal from bearings. I would like to clean them up and re oil then replace the rubber seal. I've done metal shield bearings before, is there much difference.
I say, don't. When I bought my first XRay (EVO 2 FOC,) a friend of mine told me not to because they'd never seal right again after that. I didn't listen, but he was right. I never could get them to work correctly after that. I've had good luck just cleaning them out with something like an RPM Bearing Blaster and re-oiling them without taking the shield off. Works for me.
Rob
Rob Mincey is offline
Old 11-16-2005, 06:41 AM
  #4638
dawgmeat's Avatar
\\What happen to the RDX?
Oh well, I got rid of the TC4 FT for a x-ray and love it to death
dawgmeat is offline
Old 11-16-2005, 07:01 AM
  #4639
teamgp's Avatar
You can find bearing cleaning instructions in the XRAY forum FAQ thread.
Rob,
Removing and re-mounting the seals can be done. You just have to make sure you do the following (included in the instructions):
* Flatten out any bends in the seal carefully before re-mounting them
* Put them back in exactly as they came out, to include both the correct side of the bearing to mount each one on AND the correct side of the seal that faces out
* Use the flat part of your fore finger and thumb (the center of your finger prints) to press them back in and DO NOT use any tools to *push* them back in
teamgp is offline
Old 11-16-2005, 07:58 AM
  #4640
Trader Rating: 42 (100%+)
Rookie, everyone at IRP is pretty much running the 116T.
c'mon...what about my 84T 48P. Rookie can't set mesh anyway....he only knows glow plugs! 48P man!!! muh huhh huhh haaaaaaaaaa
rookie....build that FK05 up already. i owe you that bump pass still.
Nexus is offline
Old 11-16-2005, 09:01 AM
  #4641
teamgp's Avatar
FYI, I've posted an important update in the XRAY forum for those interested in the One-way / Carpet / Foam Setup Thread...
teamgp is offline
Old 11-16-2005, 10:44 AM
  #4642
Trader Rating: 17 (100%+)
Yeah...thats what KK told me, but finding a 116T PRS is like finding a brand new Tamiya Brusier for $100.
Solara is offline
Old 11-16-2005, 10:50 AM
  #4643
Trader Rating: 40 (100%+)
Rookie,
I've ran a kimbrough 116 before I got my PRS gears in... The numbers barely touch the motor mount, so if it bothers you, sand off that side of the gear a little, other wise, just run it.. I did with no problems...
brians11 is offline
Old 11-16-2005, 10:51 AM
  #4644
Nexus....you keep practicing at IRP, ok...? and you will see me, the famous moving chicane and give you a friendly BUMP from behind in WOT....
Yeah, I am planning to build my FL05 finally....the date should be November 17 and after.....just don't know what year...
Solara is offline
Old 11-16-2005, 10:53 AM
  #4645
Originally Posted by brians11
Rookie,
Really...? Wow....if that is Kimbrough, then it is local pick up....I will give that a try...thanks.
Solara is offline
Old 11-16-2005, 10:58 AM
  #4646
wolfman76's Avatar
Rob,
Thanks for the info Team GP what a great forum. So much information.
wolfman76 is offline
Old 11-16-2005, 12:37 PM
  #4647
Glowster21's Avatar
Whats Up Dawg!!! Still have the RDX.....Best of both worlds
Old 11-16-2005, 12:43 PM
  #4648
teamgp's Avatar
The XRAY factory support team thanks you for the appreciation!
Believe it or not we're working hard on all of our customers issues.
teamgp is offline
Old 11-16-2005, 03:40 PM
  #4649
hpipro321's Avatar
love that site for set ups and wut not
hpipro321 is offline
Old 11-16-2005, 03:44 PM
  #4650
Speedo's Avatar
If you really want PRS gears, and they are very good, like I mentioned in my previous post, you can order the 116t off of PRS's website.
Speedo is offline
