Tamiya TRF416 / TRF416WE / TRF416X
#4006
#4007
I am thinking of getting the 416 and would like to know which kit I should get the 416 reg or the 416 world kit and what is the largest lipo pack can be use in either kit, do I need any other hopup for these kits or it is fine as is any info would be appreciated.
#4011
an SMC 5000 lightning volts is going to be the fastest thing u can put in there .. but the deans connector sucks..
#4012
Thank you guys.
#4014
A friend of mine got a 416WE, on the very first drive he broke the front plastic drive cup from the stock solid diff without hitting anything. Does tamiya or any other company has an upgrade for this? At the moment he's opted to get a normal diff up front which has aluminium drive cup.
#4015
Any suggestion on which connector is good or better that deans? All my packs are deans and i m thinking of trying the Traxxas connector. By the way is intellect 3800 35C a good battery?
#4016
That seriously seems like a fluke... I have chipped the outer edge of one when I bent an aluminum bone on a hard hit, but I haven't been able to brake one of the plastic cups. As of this time nobody I know of has an upgrade for the stock one, I would suggest he put a new outdrive on it and try again, with the aluminum outer sleeve it should be extremely durable.
#4017
Lots of activity in this thread lately. It's good to see more interest in this car stateside. Perhaps other hobby shops will start stocking more parts. I mentioned to Stormer that I'd love to buy parts from them, and they said they've been considering carrying 416 stuff, so we'll see.
#4018
In the past, I've been able to just peel them off with some force. The shoo goo can be removed from the case by hand. It does tend to discolor the plastic a bit. The trick is to try and not bend your weights so you can reuse them down the road.
#4019
It looks that way huh Orion sponsors me so I followed you there but Tamiya hasn't shown any love I had BMI too but after I left Schumacher and he stopped doing TC stuff it went away Maybe I'll lock my keys in my car with it running and complete my Caster transformation
#4020
