Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 07-10-2008, 03:09 PM
  #2506
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Hoggy
hey all. just finished changing my car to the short arms and putting on my Square alloy hop up parts. car looks trick, however i have come across a problem. On the left side of the car when i tighten the screw on the bottom of the C Hub it locks up the knuckle so it is not free to move from side to side you have to force it to move and if you keep moving it the screw comes loose on the bottom. i do not have the same problem on the other side. Any ideas on why this is happening?
This happened with mine when I put the square uprights on too, check you have the flanged tubes around the right way as the top and bottom ones are different sizes. The manual also says not to completely tighten the screws.
CraigM is offline
Old 07-10-2008, 10:02 PM
  #2507
Hoggy's Avatar
Trader Rating: 26 (100%+)
thanks mate thats what i had done lol. I Was also missing the washer that went underneath the top flanged tube.
Hoggy is offline
Old 07-11-2008, 01:30 AM
  #2508
TryHard's Avatar
All ready for it's 5cell mod racing debut...
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-dscf0010.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0011.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0012.jpg   Tamiya TRF416 / TRF416WE / TRF416X-dscf0009.jpg
TryHard is offline
Old 07-11-2008, 02:43 AM
  #2509
HI_808's Avatar
About four months ago, I recently switched over to lipo since my old GPs really started to give out. With the GP3900 6 cell, my TA05R + Novak 13.5SS was quick and easily controllable; the change to lipo made it somewhat erratic on asphalt whereas my TA05MS also with a 13.5SS really came to life. I thought that I'd be able to tune the TA05R to regain it's old "personality", but I've tried countless different things to no avail. Even adding ballast to make the lipo weigh as much as the GP3900 made very little difference. I came to the conclusion for my own taste, the lipo gives too much punch (probably due to the smoother discharge curve) for the TA05R.
After researching on the forum that lipo fitment isn't a problem with the 416, I finally decided to pick one up as a replacement car. It's nice to come home from work and then find that the brown truck santa clause left a TRF416 . Building the new car won't be as quick as usual since I'll be busy for the next week, though. I'm also probably going to refer back here to you guys for tips. Thanks for what you've already provided!
HI_808 is offline
Old 07-11-2008, 05:49 AM
  #2510
kentech's Avatar
I see you received the motor
With the TC Spec you should adjust the timing on the motor so the "ii" marking is towards the C motor tab.
Good luck!
kentech is offline
Old 07-11-2008, 08:00 AM
  #2511
TryHard's Avatar
Yup, did indeed.. As usual, good speedy service, highly recomend racingfactory.fl .
I take by adjusting the endbell in that way, it's retarding the timing slightly? Any thoughts on what profile to use? was thinking 4.
TryHard is offline
Old 07-11-2008, 08:50 AM
  #2512
kentech's Avatar
Great with happy customers!
Yes you're retarding the timing since the LRP speedo has quite a lot of timing built in. 4 should be good, although I have not run the TC Spec for quite some time now.
kentech is offline
Old 07-11-2008, 02:45 PM
  #2513
POUNDITRACING's Avatar
Help!!!!
I'm having trouble getting enough droop in my car.
I'm using 5mm ride heighth and want 3mm droop.
I also and 1* anti squat and 1* anti dive.
I have sorex 36 on yokomo rims.
What is the strok on the shock supposed to be?
POUNDITRACING is offline
Old 07-11-2008, 03:02 PM
  #2514
TryHard's Avatar
When you say 3mm, I guess you mean 3mm over ride hight?
You've probably got your shockends wound in too far, try unwinding them enough so that you have shocks lengths of about 61.5-62mm (from tip to bottom)
HiH
Ed
TryHard is offline
Old 07-11-2008, 03:43 PM
  #2515
That's what I thought but I needed a number. Thanks for the help.
Old 07-11-2008, 06:30 PM
  #2516
Default TRF 416
Need help here. Can someone tell me which size of below ball bearing can be use for TRF 416. Can you tell me also how many piece do i need for each set. I'm about to order the kit with the ceramic ball bearing. Thank you...
Ceramic Ball Bearing 12x18x4
Ceramic Ball Bearing 3/16 x 3/8
Ceramic Ball Bearing 3/16 x 3/8p
Ceramic Ball Bearing 3/16 x 5/16
Ceramic Ball Bearing 3/8 x 5/8p
Ceramic Ball Bearing 3x6x2.5
Ceramic Ball Bearing 4x7x2.5
Ceramic Ball Bearing 4x8x3
Ceramic Ball Bearing 5x10x4
Ceramic Ball Bearing 5x11x4
Ceramic Ball Bearing 5x8x2.5
Ceramic Ball Bearing 5x9x3
Ceramic Ball Bearing 6x12x4
Ceramic Ball Bearing 7x11x3
Ceramic Ball Bearing 8x12x3.5
Ceramic Ball Bearing 8x16x5
ichigo1661 is offline
Old 07-11-2008, 10:04 PM
  #2517
peterchia41's Avatar
hmmmmm... i don't know xD
peterchia41 is offline
Old 07-11-2008, 10:05 PM
  #2518
CraigM's Avatar
what's the silver suspension block in the front-rear of your car Ed?
Also a related question, if I want to use a 415 block in this position do I just add another 2mm of spacers? I measured the 416 and 415 blocks and that seems to be the only difference
tx
CraigM is offline
Old 07-12-2008, 03:19 AM
  #2519
Stein Tumert's Avatar
tx
Serpent S400...?
Stein Tumert is offline
Old 07-12-2008, 07:36 AM
  #2520
Hebiki's Avatar
Originally Posted by Stein Tumert
Serpent S400...?
old evoIII suspension block?
Hebiki is offline
