Serpent 733 1/10 200mm touring >
Old 03-01-2011, 02:28 AM
  #3436
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by andy733
Thanks for info,it's a real shame as it means that the car is incomplete for setting up changes
i dont think you would have had it on too long anyway Andrew. maybe Moorebank on a higher grip day. but not Little hampton.
i removed as many screws as possible to get Flex, not taking it out, and it made a world of difference.
Pattojnr is offline
Old 03-01-2011, 03:14 AM
  #3437
Originally Posted by wad
Thanks to Team Kamikaze and Serpent for all the help. I am glad to be part of this team..........
congrats WALTER.
Can you post your setup please?
implusepro is offline
Old 03-01-2011, 06:26 AM
  #3438
Seisick's Avatar
Originally Posted by ugglasdav
does anyone have any other ways of charging the IP 1450 life battery while its still in the car. i have figured out how i can wire it but i cant find a way in which i can charge it. i would have to take the top deck off the car every time if i wanted to charge it.
http://hobbyking.com/hobbyking/store...idProduct=9735
Seisick is offline
Old 03-01-2011, 07:25 AM
  #3439
Trader Rating: 8 (90%+)
Originally Posted by Team Kamikaze
Yes, you definitely need the motor mount for a Sirio engine, the mounting point of the Sirio is narrower than the Nova Rossi base and Picco base engines.
Well i guess the car already had the motor mount... everything matches up perfectly.
Tha Skinny is offline
Old 03-01-2011, 08:12 AM
  #3440
rias5037's Avatar
does anyone else have the screw on the rear diff holding the gears together come loose, mine has twice now, anyone have this, any solutions guys?
rias5037 is offline
Old 03-01-2011, 09:14 AM
  #3441
Team Kamikaze's Avatar
Never heard that happen at all, are you sure the plastic housing is not stripped where the screws goes into? I would suggest replacing the diff housing and go from there.
Originally Posted by implusepro
congrats WALTER.
Walter will post his set up later in the day.
Team Kamikaze is offline
Old 03-01-2011, 09:25 AM
  #3442
rias5037's Avatar
i think you right sam, worth a try, know the part no. off hand?
rias5037 is offline
Old 03-01-2011, 10:41 AM
  #3443
wad
wad's Avatar
congrats WALTER.
Thanks,
I will post it later on when I get back home...
wad is offline
Old 03-01-2011, 11:08 AM
  #3444
Michael_T's Avatar
Trader Rating: 52 (100%+)
Yes, it has happened to me and a number of other racers here.
You must use locktite!
Michael_T is offline
Old 03-01-2011, 01:49 PM
  #3445
lil-bump's Avatar
Trader Rating: 89 (100%+)
That's odd... I normally have trouble getting mine to come loose. I would try the locktite.
Pass you soon...
lil-bump is offline
Old 03-01-2011, 03:03 PM
  #3446
rias5037's Avatar
ok then, locktite it is, let see what happens from here, will keep you guys posted
rias5037 is offline
Old 03-01-2011, 03:20 PM
  #3447
NEVER use Loctite on Plastic, loctite contains a chemical that softens plastic!
you can use C A glue if you want but not loctite.
Part # for the diff housing is 804174,
Old 03-01-2011, 03:35 PM
  #3448
Geezatec's Avatar
Never use loctite plastic to metal. I does softed plastic. I use a hot glue gun on the screw threads, if in a bind. Purchase a diff housing as Team Kamakazi suggest. Useing CA you definitely purchase a new diff housing after a while. Try putting nail polish on the screw & plastic, if its cracked, its loose.
Geezatec is offline
Old 03-01-2011, 04:19 PM
  #3449
Michael_T's Avatar
I think there is some confusion here. The way I am reading it, he is referring to the screws that holds his diff gears (ie, the screw that goes into the outdrive) is coming loose.
I have seen this happen several times, it happened to me causing the diff to seize.
As this is metal to metal, loctitie is the fix.
See photo of what I am talking about...
Attached Thumbnails Serpent 733 1/10 200mm touring-111.jpg
Old 03-01-2011, 04:33 PM
  #3450
quietstorm76's Avatar
Trader Rating: 12 (100%+)
Yeah it's happen to me once when i first built the car. . The screw backs out and the outdrive binds against the dog bone. Just use a little blue lock tight if you ever want to take it apart again.
quietstorm76 is offline
