Serpent 733 1/10 200mm touring
#3286
hello guys,
just got my 733 for replacing my favorite 720.. As i am new
to the 733 platform, i am thinking how good the default setup
as a starting point. i mainly run on a flat, technical track
with quick direction changes, most of the time low-to mid traction.
Is the 720 setup applicable to the 733 chassis, or should i look for
a complete different setup?
i know the diffs are a lot smaller than the 720's , on the 720 i mainly
run 80.000 with 20.000-30.000 on the rear. What would be a good
starting point on 733?
#3287
hello guys,
http://www.serpent.com/product/804000/setups/
#3288
hello guys,
#3290
everyone has a hole!
#3291
Is 733 coming our new EVO version? Is yes, what is the different?
#3292
from what i have heard, the new 733 will include v2 rear end parts (http://www.serpent.com/product/804222/). Some people
claim that it will also include the dls system but this is not what i have heard.
i am about in the middle of the building process, my kit came with the M nylon parts, and the kevlar(orange) belts. So far so good, with some personal comments:
1. in the front diff, i used my dremel to lower just a little bit the screws on the diff
and the pulley.
2. i had to use my dremel also on the pivot balls connecting the front roll bar
with the suspension. I lowered them about 1mm to achieve the 27mm distance recommended by the manual, and have some adjustability.
3. on the brake system, one of the 2 pins holding the springs was a little tight on the spring causing the spring to bind, so i used some fine sandpaper.
4. the rear lower suspension arms are tighter than i would like, but i left them without any modification until i run the car and see if they free a litle bit.
everything else went pretty good, alu parts have excellent fitting. i also opened the bearings and added a drop of premium lube. i like the premium
lube because its thicker than the bearing lube, and keeps bearings lubed
for a longer time.
and the pulley.
for a longer time.
#3293
i thought that you will had leave the build for 2012!
#3294
#3297
just bought the DLS kit from Rc Mushroom (10 free filters ), can anyone tell me if this will improve rear end traction, we dont have a high traction track at our club, we normally use 35 rears and 40 fronts and almost a 3.5 to 4 toe on the rear to stop the car front sliding out, will the DLS help in cornering and bringing the rear toe out a bit as well, with that toe we scrubing tires so tire wear in the rear on 35 shores are more than average.
#3298
#3299
anyone know why on the instructions of the dls system that there is an orange spacer on one side of the car and not the other
