Serpent 733 1/10 200mm touring
#4036
#4039
-Wider Bumper for less air turbulence at the front (more steering in high speed corners)
-Flex System at the front
-new radiotray (less weight i think)
-new front geometry (the upper links are shorter i think)
-Do you also see new shocks???
I hope there will be more pics soon... redrc will be the first i think...
wonder how it will be named ;-)
#4040
AND just compare the holes in the chassis under the engine mount......
#4042
Starting the first day of the toy fair at the Serpent stand, we were shown around the huge number of new products in their booth. First up is the new 747 1/10th scale 200mm chase which features new geometry front and rear as well as a front flex system that through the use of two tie rods connecting the front blocks to the radio plate can help adjust the chassis flex. A new radio plate retains the configuration of the 733 but with the radio box removed. A nice feature of the car is the new symmetrical chassis plate that sports an area for mounting weight to the centre line of the chassis which can be moved forward or rearward to influence the cars balance. Other new features include new RCM shock absorbers that now feature membranes again instead of the foam inserts.
#4044
An all new chassis the 747 sports new uprights and shock rod extensions on the lower rear wishbones for additional mounting options. A new centax clutch true motion sports a tapered flywheel as seen in some of its competitors cars and a the gear diffs have been updated with smoother running gears and smaller shafts for lighter weight. We are told that the car will come in at close to the proposed new weight limit by EFRA.
http://www.redrc.net/2012/02/toy-fai...nt/#more-51361
#4045
Pics
#4048
Do you use DLS that often???
Since driving 733 i just tried but never used DLS....
In my opinion, DLS just makes the car feel a bit different but doesnt make it faster..
For me the car is perfect, even without DLS.
So here my question:
Do you use DLS just because its a nice and unique option or do you think it really makes the car faster???
Best regards
Daniel (Germany)
Best regards
Daniel (Germany)
#4049
Best regards
Daniel (Germany)
Best regards
Daniel (Germany)
